RCA Cables
sntnsupermen131
Is Rockford Fosgate's matrix gamma the best RCA cables to buy?
I was wondering because I installed my system in this weekend and was wondering if that was the best wire to go with
one more thing, from the mm120s, to the terminal, to the amp, what size wire would you need?
is 12 big enough or is it too small??
Thanx
-Cody
Thanx
-Cody
Post edited by sntnsupermen131 on
i would use 12 or 10, but the best idea would be to have the wire go right through the box (no terminal cup).... mainly because the "gauge" of the terminals is usually less than 12 or for that matter, 16 ga. wire.... just drill a large enough hole for the wire to go right through the box, and then caulk it in.
my 2 cents -
one more thing
about how efficient should a 1000 watt amp be?
im going to order a capacitor today off of ikesound.com and as soon as i get it ill install it
-Cody -
well, it's not so much how efficient the amp is, as it is how efficient the electrical system is in your vehicle.
if when the bass hits and your lights all significantly dim.... then you definitely need a cap., but if there is no real dimming of lights, or anything similar to that.... you should be fine for the most part.
