Comparing 3 subs....
Hi, I am trying to choose the most powerful sub between 3 choices I'm actually considering. When I mean "powerful" I mean the sub which sounds louder and the sub the moves the most air of all.
The 3 choices are the following:
* A SQUARE Kicker Solo-Baric S15L72 that's got 15 inches, 1000 RMS of power, double coil, works at 2 ohm.
* A round JL Audio, which is 15 inches and it's got 1500 RMS of power, it's also double coil, works at 2 ohm.
* Two round Kicker CVX15, each one of them has got 15 inches and 1000 RMS of power, double coil, works at 2 ohm.
Let's supose that in each of the cases I got the necessary amp to power them to the MAX.
I appreciate your responses concerning this thread....
  • Schris22
    Schris22 Posts: 983
    edited May 2006
    I would try the car audio forum.
    Just scroll down to the bottom on the main forum page. You'll get more response there.
    Good luck
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
