Is DTS usually Louder than DD?
groover
I've recently updated my receiver to an RXV2600, which means I can finally play DTS tracks. I have found them to be a lot louder than DD and wanted to ask if this is normal? I find myself seeking out my DTS movies for some serious sound immersion
Post edited by groover on
DTS is basically a less compressed version of DD. I find DTS is louder and more dynamic on my sytem as well. I also seek out DTS recorded movies when I am shopping.
I am sure I am most entertaining to my friends when they are over. When I play a DTS movie I always jump up and point to the DTS illumination on my receiver and yell "DTS in the house" :cool:The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
This is pretty f***ed up right here. -
I must admit, I'm also smitten with all the speaker symbols lighting up and seeing DTS on the front panel. I didn't know what I was missing. We watched Reign of Fire the other night (first DTS movie) and when the dragon came out of it's hole and up the shaft my wife almost shot off the couch with the dynamic punch of the sound and the sub rumbling so much - almost made me laugh - after recovering from the shock of it
Enjoy it Groover. There are more and more titles popping up on DTS. I could recommend a whole slew I suppose, but hoping that you enjoy music I will recommend the Eagles, Hell Freezes Over.
The only negative I can say is they chose to play many of their softer hits and the middle of the DVD gets quite sappy. Still the overall sound is great.
Happy listening.The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Yup Groover, DTS rocks!!!
While you are picking up HFO also pick up their Farewell 1 tour as well! They play all of their hits in the original style in glorious DTS!!! 3 hrs worth of music! The Eagles Rock!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
The LFE for DTS is 3dB cooler than the same DD track in my setup, and I've noticed the mains are a few dB cooler as well. However, DTS is more spacial, directional, and just flat out sounds better once the volume is cranked a couple notches more on the dial. As said before, this is true because of the higher bitrate. I've also noticed that DTS only DVDs (higher bitrate than dual DD/DTS soundtrack DVDs) sound even better. However, I have found that the best movie soundtrack is the DTS track on the LOTR Extended editions; IMO of course! I have a Denon THX Ultra certified AVR-4800 receiver.
Hopefully lossless audio will make its way to blu-ray/hd-dvd and the playing field will be leveled out. But judging by early disks, the trend is still to compress the audio albiet at a higher bitrate this time.Fronts: DIY Statements from htguide.com
Center: DIY custom Statement center from htguide.com
Surrounds: Four DIY custom Mini Statements
Wire: HD-14
Receiver: Denon AVR-4806 + CI upgrade
Amps: Dual Emotiva LPA-1's
Sub: Infinite Baffle: 8 fiCarAudio IB315 woofers, Behringer DSP1124P EQ, Elemental Designs eQ.2, Dual EP4000 amps
Transducers: 2 buttkicker LFE's, BK amp, EQ'd w/DSP1124p
DVD: Toshiba HD-XA2 / PS3
TV: Samsung 1080p 61" DLP -
Usually. But i've recently discovered "Dolby VS Wide" on my receiver. It's a 5.1 implemenation of Dolby Digital's "Virtual Speaker" Technology that not only sounds louder than DTS, but it imo it sounds better. More spatial, dynamic, better dialogue intelligibility, etc. If your receiver has it, I would seriously consider it. It's become my new default for 5.1 material.
Last night I watched Kingdom Of Heaven, and did an A/B comparo between the DTS mix and the Dolby VS Wide- there was no comparison between the two. -
groover wrote:when the dragon came out of it's hole and up the shaft my wife almost shot off the couch
Sorry Grover I just couldn't help myself.
I noticed DTS is a bit more defined in which speaker the sound is comming from. It also seems abit louder.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Quote:
Originally Posted by groover
when the dragon came out of it's hole and up the shaft my wife almost shot off the couchSkynut wrote:Sorry Grover I just couldn't help myself.
I see what you mean. Re-reading it I went red
Funny how some things read after the fact! If the actual situation seemed funny, then this is even funnier:D -
groover wrote:I've recently updated my receiver to an RXV2600, which means I can finally play DTS tracks. I have found them to be a lot louder than DD and wanted to ask if this is normal? I find myself seeking out my DTS movies for some serious sound immersion
Congrats on your upgrade.. DTS rocks it hard.
PolkFest 2012, who's going>?
Nice receiver I have the 2500. DTS does sound great, but I think both have their advantages.Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
Zen Dragon wrote:DTS is basically a less compressed version of DD. I find DTS is louder and more dynamic on my sytem as well. I also seek out DTS recorded movies when I am shopping.
nerd alert...
just playin with ya ;-)-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR -
It's a nerd alert if you just say in casual conversation, "Gee guys, did you know we have DTS in the house here and it's just swell"
When yelled with authority, with some urban ethnic accentuation on the word "howwwse" it's not nerdy at all. More obsessive or physchopathic actually.
The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
Exactly
Zen Dragon wrote:It's a nerd alert if you just say in casual conversation, "Gee guys, did you know we have DTS in the house here and it's just swell"
It is a little urban nerdy, really...
Besides the Eagles, which I will probably go out and buy tomorrow....What other DTS music DVD's are there that rock?HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
Pick your poison.
http://www.amazon.com/gp/richpub/listmania/fullview/26OEQ2C3RC74P/104-5373097-7817558?%5Fencoding=UTF8The Family
Polk SDA-1C's
Polk SDA-2
Polk Monitor 10B's
Polk LSI-9's
Polk Monitor 5's
Polk 5 jr's
Polk PSW-450 Sub
Polk CSI40 Center
