New Stereo Cabinet
Holydoc
Holydoc Posts: 1,048
edited May 2006 in Electronics
I know it is nothing compared to some of your rigs, but I wanted to show you what the new stereo cabinet I purchased from Diamondcase furniture.
Yes...yes...I am still waiting for Panasonic to make my new 50" Plasma (600U series) so ignore the tube TV on top. You just have to pretend. I am still addicted to "Lost" so I need something to watch it on until I can get the Plasma mounted.
Front View Closed
Front View Open:
Side View:
Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote
Post edited by Holydoc on
    F1nut Posts: 52,007
    edited May 2006
    Looking good!
  • cfrizz
    cfrizz Posts: 13,415
    edited May 2006
    It must have a very high WAF as well!;) :D
  • bikezappa
    bikezappa Posts: 2,463
    edited May 2006
    Can you make things, like candles, vibrate off the table?
  • Holydoc
    edited May 2006
    Bachelor pad. Seems I am the picky one in the household. The two himalayan cats only require food and a place to jump on. So is that maintaining a high HAF (Himalayan) or CAF (cat)? Here is a picture of my boys I took with my cell phone (thus bad quality) as I was leaving for work:
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited May 2006
    Looking good.
    Try bringing your 12's out a little, break that 'plane' of the front of the cabinet.
    Cheers,
    Russ
  • cfrizz
    edited May 2006
    Beautiful cats! Yes they approve, & if they are very adventurous they might decide to pose on top of your speakers or warm themselves on the back of the TV!:eek: :D My Tammy use to like doing that!
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2006
    Very nice Holydoc!
    If...
    Ron loves a film = don't even rent.
  • brettw22
    brettw22 Posts: 7,623
    edited May 2006
    What kind of carpet pattern is that in front of the stand?
    I like that you can eventually grow into a 80" LCD TV in the future, so you've done well in that regard. Also, I'd bring your center out a little bit.
  • Shizelbs
    Shizelbs Posts: 7,433
    edited May 2006
    Very nice looking.
  • Holydoc
    edited May 2006
    Brett,
    I have a Roomba Vacuum cleaner (i.e. a robotic vacuum). That is the pattern it makes against vertical services as it "feels" its way through the room.
    Yes...yes... I like my house automated...umm... or I am lazy. I can't remember which.
  • janmike
    janmike Posts: 6,146
    edited May 2006
    Very Nice. What's the load factor on that versus the weight of your TV? I had one a while back that indicated 200LBS and the TV weighed 120LBS. Within a week it started to buckle and I pulled the TV off.
    Michael ;)
    NORTH of 60°
  • MattN03
    MattN03 Posts: 558
    edited May 2006
    Nice looking cabinet!
  • Holydoc
    edited May 2006
    According to the maker (Diamondcase Designs), there is no TV 60" or smaller that will buckle it. It is tongue grooved and glued with Birchwood designed to hold a lot of weight. Even with all my components and this very heavy tube TV, it does not even give or creak when I push it around on my carpet.
    It also has three exhaust fans built into the compartments. These fans are speed adjustable so that if you are pushing the system during a movie, you can crank it up, or if you are just listening to romantic music you can keep them turned down to just keep the heat off.
    However, a bit of caution. It was not cheap. I think I will start riding my bike to work. :)
