Rti with M30
dharris1969
My wife and I have decided to take a more conservative approach with our home theater. I can spend up to around 1500.00. What do you think of this combination?
A/V - NAD T753 70wpc Continues
Mains - RTI 6 on Studio Tech metal led shot filled stands.
Center - CSI 5
Rear - M30 or RTI 4
I would like to keep the cost down as much as possible.
As said before, I listen to 50/50 music TV, but I will have a completely separate 2 channel system for music. So this system is mainly for Home Theater. I have two 10" 250w Def Tech subs that will go with this system.
Thank you for any suggestions you may have.
Don
Center - CSI 5
Rear - M30 or RTI 4
Don
TV - Sony 36" KV-36FV27
A/V Receiver - NAD T753
2 Ch Amp - Rotel RB-870BX
CD - Rotel 930AX
DVD/DVDA - Panasonic DVD-A7
Panasonic SACD / DVDA
Speaks,
Main - MB Quart QL S830 4ohm @ 87 DB
CC - MB Quart QL S330CTR 4ohm @ 90 DB
Rear - MB Quart QL S530 4ohm @ 85 DB
Sub - Definitive Technology PRO Sub 100 TL
CD - Rotel 930AX
Speaks,
Post edited by dharris1969 on
Thats not a bad start at all, you will enjoy that setup. Since you did list them as an option I see no reason not to go with RTi4's in the rear.
Despite the fact that for HT some consider the rears not quite as important as a consistent main stage, I'm a firm believer that whenever possible stick with the same line all the around.Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
Secondary System: Polk RTi 6 L/R, CSi3, Center, FXi3 x4 Surrounds, Def-Tech Supercube II, Pioneer Elite VSX-23 Receiver -
Would you know if there are big audible differences between the CSI3 and 5 centers?TV - Sony 36" KV-36FV27
CD - Rotel 930AX
Speaks,
Sub - Definitive Technology PRO Sub 100 TL -
The CSi3 is also a solid performer. If cost is an issue, I would base my choice on room size. For larger rooms the CSi5 should be the choice.
I have a CSi3 in a room thats approximately 12x12, and it's more than adequate, however, my main theater is a tad bit larger, and needs the more pronounced presentation of the CSi5.Main theater: Paradigm Studio 100's v4 L/R, CC690 Center, ADP 590 x4 Surrounds. Dual Outlaw LFM-EX-1's, Yamaha Aventage RX-A1010 as Processor, Anthem PVA-7 Amp
Nelson57 wrote:The CSi3 is also a solid performer. If cost is an issue, I would base my choice on room size. For larger rooms the CSi5 should be the choice.
In my case I think I will need the bigger of the two. Thanks for your help.TV - Sony 36" KV-36FV27
CD - Rotel 930AX
Speaks,
