How would you configure these speakers.
Here's the setup: One CS1000 center speaker; four RT3000's; two f/x1000's.
In a 7.1 system should I use the f/x1000's as the rears or as side surrounds? Vice versa should I use the second set of RT3000's as side surrounds or back speakers? Where do I use the two additional subwoofer's from the extra RT3000's?
I'm leaning towards using the f/x as back speakers and line the front with the sub's. Then placing the top sections of the RT3000's high on the side walls.
What would you do?
Darrin
What would you do?
Darrin
Post edited by dbartol1 on
I'm not an HT guy, but I think the consensus is to put the multipole speakers on the sides (F/X), and the direct radiating in the rear.
Cheers,
RuSsMaN wrote:I'm not an HT guy, but I think the consensus is to put the multipole speakers on the sides (F/X), and the direct radiating in the rear.
Cheers,
Russ
+1 :cool:
