Interconnects
Having a hell of a time figuring out what to buy exactly. I have been going to tweeter's as of late and every time i want to buy cable's of any sort of course they tell me to get audioquest. But it just get's a little to price for my taste. Looking for something affordable but still has good quality. Thanks
Samsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects
Sony BDP-S570
Magnepan MMG's
Polk R15 Surrounds
Audioquest Cables
Post edited by jhermance on
I purchased IC's from Signal Cable and found both the price and quality to be very good.Michael
NORTH of 60° -
raymond cable on ebay.
Check them out good price and build Quality.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
cobalt cable.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
JH, there're quite a few suppliers that fit your requirements; consider MonoPrice or Total Signal .
SYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables -
I was recently planning to buy a CD player (Rotel) and the dealer said that I need to buy this $350 interconnect cable by Siltech to do justice to the CD player.
I was thinking of going with around a $70-80 interconnect from Cobalt Cable.
I just can't comprehend that a $350 cable will make the player sound better than these $80 Cobalt Cable interconnects.
Yeah sure, technically they may sound better but can the human ear really pick up those subtle differences???
Any thoughts?Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes) -
I think yes you can hear the subtle differences but its just that. Subtle. So is the extra money worth the price jump? Only you can answer that. Obviously with your budget (which is still a damn good price range), I don't think you're gonna spring for it and honestly, I can't blame you. Now if you were buying a $3k CDP, it might be different. It's all relative IMO.Never kick a fresh **** on a hot day.
Thanks Toxis - looks like you recommend Cobalt Cable.
Do you like them? How are the Cobalt Cable speaker wires and interconnects? If you've used them - have you noticed a difference?
My dealer gave me free speaker wires and they seem quite good so I'm debating about spending money on cables at the moment.Distant Dream - A New Beginning
I bought a pair of Audio Quest copperheads. I did an A B comparison with regular interconnects and the copperheads. I don't have the BEST ear, and I had a really hard time telling the difference between them. My testing was very limited (a couple songs), but the difference was so minimal that I'm not sure I heard it. I'll do some more testing because $80 for a pair of interconnects is a hell of a lot of money for almost no difference.
I have an ear enough to tell the difference in the DACs on the 3805 and 3910 though. So I have some idea of what I'm hearing...Denon 3805S
Denon 3910S
Polk LSi 15's
Polk LSi F/X's
Polk LSi C
Boston Pro 10" DIY Sub
Samsung 5678W DLP 1080P
PS3 -
janmike wrote:I purchased IC's from Signal Cable and found both the price and quality to be very good.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Chalk up another vote for Signal Cable:)I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
