Three way or two way?
i dont know if anyone has ever posted a thread on this but here goes, is there audibly a difference between a two way design speacker and a three way design aside form the three way being more difficult to make and more expensive to make. i have personally never own a three way designed speacker so i just dont know if there is a difference at all. this is just useless info i'd like to know.
i am getting the Rti8 soon and dont have the proper equipment for now to drive it, this being ONKYO 501e. are there any precaution i need to take so as not to Damage the speacker while saving for better gear? (if i am asking a stupid question here please ignore me.)
the sales man suggested the ONKYO 603 for the Rti8's does anyone have any other brands they can suggest. Something that sounds clean, but good low end as well.
(((((STEREO)))))
System 1(complete)
Front: Rti8
Intergrated: Valve Audio Epsilon
CD Player: Xindak Muse Delux 1.0
Media Player: Mede8er MED 200
Behringer DAC
System 1(complete)
Front: Rti8
Behringer DAC
Regarding 2-way vs. 3-way, it depends on the particular design. Performance and one's personal sound preference can be all over the map for both types.
Regarding receivers, Harmon Kardon and Denon are good recos for the RTi line. I recommend getting a receiver with pre-outs for all channels in case you want to upgrade to external amps for better sound. The Onkyo 603 lacks pre-outs.
Here are some good prices on Harmon Kardon refurbs:
http://www.harmanaudio.com/search_browse/default.asp?brand=HK&market=HOM&sp=S&cat=REC5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
FWIW - The RTi8 is a 2 way, it just runs 2 woofs together.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
What is the diff on 2 -3 way?
crossover mostly.
In general...
Most 3-ways have a tweet, midrange, and midbass...
Or a tweet, midbass, woofer - or tweet, midrange, woofer.
In other words, there is 3 crossover points.
I would take a 2 way over a 3 way, just because the crossover is so important, the 2 way should be the better speaker, within the same line.
Polk mostly makes 2.5 ways.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
3-Ways could get messy....
Man aint that the truth!
Have you heard them old POS rack system speakers, Pioneer, JVC made some. KLH came out with a few...
I think the midrange just played something, completely overlapping into the tweeter and woofer range, horrible sounding stuff...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I too am looking to get a set of Rti8's i have a Pioneer Elite Vsx-37TX Receiver i hope it will do the job well enough. Good LuckSamsung UN46C7000
Cambridge Audio 640R
Sony BDP-S570
Magnepan MMG's
Totem Dreamcatcher Center
Eleganza Bella 1200 High Performance Subwoofer
Polk R15 Surrounds
Audioquest Cables
Panamax 5510-PRO AC Regenerator
Monster Cable HTS 2500 MKII power cleaner
Nordost Blue Heaven Interconnects -
adam2434 wrote:Regarding 2-way vs. 3-way, it depends on the particular design. Performance and one's personal sound preference can be all over the map for both types.
I have RTi70's that sound fantastic being driven by my HK AVR-635. I have never heard a Denon in a setup similar to mine, but can definately say you should give the AVR-635 a listen. Fry's electronics usually has RTi8's hooked up to an HK 635 if you have a Fry's nearby.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
WOuld the Denon 1906(not sure if this model number is correct) be sufficient for the Rti8 or would i need to go with the model above this. i know the 1906 has pre outs. Would i need to stick within the same brand for the power amp when i later decide to upgrade or is it okay for me to use a different brand?(((((STEREO)))))
System 1(complete)
Front: Rti8
Behringer DAC
