Small Engine Repair
MrNightly
MrNightly Posts: 3,370
edited April 2024 in Clubhouse Archives
Anyone know anything about small engine repair?
I've got a power washer, from Sears (Craftsman I think - briggs and stanley maybe?) and it will turn on, but as soon as I squeeze the handle to spray, the engine starts to die. If I let off, it'll fire back up.
I used it for the past 3 days, and no problem, but yesterday it started acting up.
Any ideas or experience in these things before I take it back to the store and have a tech look at it?
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
  • opus
    opus Posts: 1,252
    edited April 2006
    Have you checked the oil level? Does it have a low oil shutoff?
    Also check and make sure you haven't moved the choke lever or gas shutoff valve.
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • MrNightly
    edited April 2006
    Ya, at first I thought it might have been the oil level, but I added engine oil to it. Now i'm wondering if I overfilled it?
    Choke lever and gas shut off valve? I haven't a clue what those are. I know there is a choke when you start it, and you can move from STOP to Turtle (Slow) to Rabbit (Fast) but that's all!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • amulford
    amulford Posts: 5,020
    edited April 2006
    You are having a problem with the Carb. Take it to a repair shop, unless your comfortable replacing it.
  • ND13
    ND13 Posts: 7,601
    edited April 2006
    Naww Ant, let 'em just tear right into that sucker.:D :D
    Gotta learn somehow;) :D
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • opus
    opus Posts: 1,252
    edited April 2006
    MrNightly wrote:
    I've got a power washer, from Sears (Craftsman I think - briggs and stanley maybe?) ?
    David the first thing you need to do is get you a "Briggs and Stanley" repair manual:eek: :p
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • MrNightly
    edited April 2006
    I took off some little box on the front, cause I thought maybe the the air filter was bad or clogged. When I opened it up, a bunch of oil spilled out... is that what you call "Learning somehow?" Hehe.
    It won't turn over now... sounds flooded. I think I best not break it any further!
    Oh, the air filter seemed just fine to me when I found it :) Must be the Carb. :D How do I fix that??!??!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • madmax
    madmax Posts: 12,434
    edited May 2006
    :D
    madmax
    Vinyl, the final frontier...
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2006
    You have the main fuel jet clogged, remove the fuel bowl cleaning the main jet in the center.
    BTW I agree with the manual thing pictures pictures you need PICTURES.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • keith allen
    keith allen Posts: 734
    edited May 2006
    Get rid of that champion sparkplug and put ya in a ngk!
  • MrNightly
    edited May 2006
    Ok ok.. so it's BRIGGS AND STRATTON not whatever else I thought it might have been. Geez, can't a guy catch a little slack around this joint or what? :D
    So now that we are all on the same page as to what BRAND we are dealing with, what next?
    Joe, you think I should take apart the what?! And how do I go about cleaning that? I'm very mechanically minded here can't you tell? I think I'll do a search for a manual or something, since I don't have it.
    Oh boy.. might be easier to just send it in to a repair tech don't ya think? How hard is it to clean a main fuel jet?
    If nothing else, you guys sound like you know what you are talking about.. so that's half the battle!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2006
    you most definately need to summon the help of billy bob/carl from 'slingblade'......"uuuuuhhhhhmmmmm".
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2006
    I just had the same symptom and dj nailed my solution. I remove the carb then the bowl. Inside the bowl you will see a float and under the float the check valve. Get an old tooth brush and a small bowl of gas and clean all the varnish off of all the parts. Put everything back together and you'll be good to go.
    HBomb
    ***WAREMTAE***
  • MrNightly
    edited May 2006
    Ok, sound simple enough.. but what does the Carb look like? I found a manual online http://www.generac-portables.com/data/pdf_files/pw/1441_0en2w.pdf but it's not the exact same model as mine. I guess I can just start digging into this and see what I find out.
    Also, where would this Carburetor be located at??? Sorry for the dumb questions, but remember who you are dealing with here, not an engine guy!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • BIZILL
    BIZILL Posts: 5,432
    edited May 2006
    perhaps take it to a pro. we are shooting in the dark. you may end up spending more in the end listening to us. but give her a try, so long as it's free. disney sounds confident.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • HBombToo
    edited May 2006
    The air cleaner that you popped off is attached to the carburator and has the the springs controlling the governer. That said, the bowl(literally speaking) is where the gas pours in from the gas tank. This bowl houses the float and check valve. The carburator in its entirety is bolted to the engine and controls the flow of fuel into the clylinder head.
    HBomb
    ***WAREMTAE***
  • madmax
    edited May 2006
    Maybe the cadillac converter is bad? :D
    madmax
  • MrNightly
    edited May 2006
    madmax
    Now common.. do you think i'm totally clueless here?? Ok you don't have to answer that. :D
    I'm just gonna tear it all open and see what I can use my wife's toothbrush on :D:D:D
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • HBombToo
    edited May 2006
    NOW she will really hate us Polkies;)
    ***WAREMTAE***
  • polrbehr
    polrbehr Posts: 2,852
    edited May 2006
    It'll seem stupid (it did to me after replacing the carb), but check the gas
    CAP. Seriously.
    I have a Toro snowthrower that exhibited the same symptoms you described,
    Mr.N . It would start fine, run fine, then die as soon as the drive wheels were engaged or the auger was started. A brand new carb solved nothing. It turned out that there are vent holes in the cap which were clogged, creating
    a vacuum in the tank once the gas started to flow. A toothpick was all I needed to clean out the four vent holes. It's been running fine for 5+ years now. And just for the Hell of it, I reinstalled the old carb just to see if it was OK, and ... well, figure the rest yourself! Just my .02 , but it worked nevertheless.
  • disneyjoe7
    edited May 2006
    A clogged cap LOL :D
    As far as a NGK plug... I don't think so, **** plug for **** engine GM plug for GM engine, German plug for German engine. I'm a BIG fan of NGK plugs but I'm a BIG fan of **** cars / trucks. I own a 5.5k generator with a 10hp B&S engine so I'm looking forward to the maintence I'll need in the future.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
