PSW650 vs PSW550
Steve@3dai
Steve@3dai Posts: 983
edited May 2002 in Speakers
From what I can tell, the major differences (as far as reproducing audio) is just 3dB lower on frequency response and -3dB Lower Limit on the 650.
Has anyone done a comparison between the two? I am more concerned about music than home theater for myself.
I have LSi9 fronts, LSiC, and LSiFX.
Paul (which also has the 9 fronts) uses the 650. Is that going to be too much boom?
- Steven
LSi 9/C/FX
Arcam AVR-200
Post edited by Steve@3dai on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2002
    The PSW650 will simply move more air than the 550 - it has two 10" drivers - easily more surface area than the 550. That will be the biggest difference, I would say.
    Bass port technology, driver construction, and amp is similar between the two, so I would expect them to sound about the same.
    If you want to pound out the bass - get the 650, especially if your room is big.
    Spec
    SVS
