Denon AVR 1010
labrat
I was scanning the auction site last night and ran across this as a local sale. From what I have been able to gather it is a prologic only AVR made in about 1990 that does 35w x 3 OR 100w x 2. (How does the 3 channel work - I thought even the original pro logic was 4 channel with mono surrounds) If the price were right would this make a half decent stereo rcvr? I am thinking of it as a possibility for a pair of monitor 5 jrs. Does anyone have any info on how much this should go for or if it is even worth considering?
Thanks in advance for any help,
Scott
Scott
Post edited by labrat on
labrat wrote:From what I have been able to gather it is a prologic only AVR made in about 1990 that does 35w x 3 OR 100w x 2. (How does the 3 channel work - I thought even the original pro logic was 4 channel with mono surrounds)
It's possible that this Pro-Logic receiver has a mode called "Dolby 3 stereo", where the receiver generates a center-channel signal for systems without surround speakers. I have a Technics Pro-Logic receiver, which I currently use as a headphone amp, that have this mode. -
I too have a pro logic rcvr that will do 3 channel logic - should have thought of that.
I also have a Denon AVR 1403 - rated at 70w x 5. By my way of thinking the 1010 should sound very similar when played in stereo as I would use it. Has anyone ever used this or other vintage (~1990) Denon's that could verify this for me?
Thanks,
Scott -
Also could be that it only has three ch's of internal amp, but pre-outs for two surround ch's...
MSRP: $1,000.00
USED: $185.00More later,
Tour...
Vox Copuli
Tour,
Thanks for the pricing info. If it goes cheap I will be all over it but it seems that for close to 200 there are a lot of other good options - or am I missing something special about this one?
Scott -
Scott,
I know nothing of this piece specifically. Price info was straight out of a price guide to which I have access.
If you want more info on the 1010, Denon has a pretty good "older models" section on their web-site.More later,
Tour...
Vox Copuli
Since I won't have a chance to audition this AVR, does anyone know how the older Denon's sound compares to the newer versions?
Scott
