Stupid question about CD bass...
I'm a complete newbie to the area of sound, so perhaps someone can help me out.
Just wondering why I don't get any bass when I'm playing CDs on my 360/DVD player. I understand that most CDs aren't 5.1, but shouldn't my receiver 'fake' the bass signal or something? If not, is there any way to do so?
The reason why I think it's possible is because my car can split the bass signal to the bass fine.
Thanks for any help,
Sven
PS: Please don't flame me :)
Post edited by SuperSven on
  • bknauss
    bknauss Posts: 1,441
    edited April 2006
    Are you just using the straight stereo pass through? If so, your sub is probably not getting any signal and you're going to be limited by your front speakers. In your car, the head unit usually will crossover the signal and send the low stuff to the sub and all the rest of it to the full range speakers.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • danger boy
    danger boy Posts: 15,722
    edited April 2006
    Sven
    what's the rest of your set up look like? what speakers are you using? do you have a sub?
    PolkFest 2012, who's going>?
  • SuperSven
    SuperSven Posts: 4
    edited May 2006
    I have the SurroundBar and a 12" sub from Polk. I'm connected to the receiver from my 360 by an optical cable. If I play the 360, my game will have bass, but my ripped music does not. am I missing a configuration setting?
  • EricBurg
    EricBurg Posts: 64
    edited May 2006
    Make sure your reciever setting for your speakers is small or if you prefer large, that your sub setting is plus. If you are listening to stereo bass, then you want to make sure that the frequencies below the crossover point are being directed to your sub. If you have your speakers set to large and don't have the plus setting (may be called something else) on, then the only signal you will get will be the LFE or .1 signal. 5.1 soundtracks will send the bass to your sub, but stereo tracks will not.
    Eric
    __________________
    Pioneer 1015
    Rotel 1080
    Rotel 1075
    Rti10: L/R
    Rti5: C
    Rti6: LS/RS/LSB/RSB
    SVS pb10-isd
  • drew spelts
    drew spelts Posts: 310
    edited May 2006
    what receiver are you using? Be as complete in your explinations as possble for the best assitance. I would love to help but I need to know if what I am thinking of suggesting is even worth the finger movements.
    Harman Kardon AVR635
    RTi10's Up Front
    CSi5 Center
    RTi6's Rear Surround
    Furman RA-1210:rolleyes:
  • aaharvel
    aaharvel Posts: 4,489
    edited May 2006
    small all speakers, sub set to on. It's quite possible that your CD analog L/R" configuration is set differently than the DVD Digital out on your receiver.
    Also, the .1 tends to have bass overkill on dvd's, at least in my opinon. I've never been a fan of the .1 channel myself.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • danger boy
    edited May 2006
    properly set up.. a subwoofers bass extension should compliment the rest of your system.. not dominate it. if all you are hearing is thump, thump, thump.. then the set up is not right.
