Stands/Mounted/hanging your FX300i
jdelan
Can anyone recommend any good mounts or stands for the FX300i? I don't really wanna hang these from a Screw as they are a little heavy and I do value my wall, even a little bit...
Suggestions anyone???
Post edited by jdelan on
You may want to check with your local funiture stores, I found 2 stands match my funitures and fit the Polk F/X500i. It's kinda tough to find speaker stands that fit the triangle shape of the 300i... Good luck...
It's also tough to find stands that will lift them up above the listening area, which is where surrounds should be. I know here, we had to make them in the woodshop when we needed taller stands. You could try to make them yourself.
With good anchors and serious screws (and a stable wall), the 300i's should be okay hanging on the wall.
MC -
Well, since the WoodShop I requested was not included with the Condo, Is there a bracket out there that can mount these on the wall? There has to be something...My walls are not the best and I am not the best carpenter so I just need some basic ideas to get these on the wall with the least amount of carpentry...
Thoughts, ideas???
