C300.2
heXtant
Question.
If I bought 2 8" Polk MM2084 Subwoofers, would a Polk MOMO Carbon C300.2 Amplifier be enough to power them? With the C300.2, should i get the SVC or the DVC MM2084s?
On Polk's site, it says the C300.2 can give 220w x 2 on 2 ohm. The MM2084's reccomended power handeling is 200w. Can they be wired in 2 ohm? Any help is appreciated.
System in construction..
Post edited by heXtant on
A pair of the DVC subs will work, and extract all of the power that you paid for with that amp. I would wire them together to get a final impedance of 4ohms and then bridge the amp to them.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Either way would work but youd get the most power by going with 2 DVC subs, wiring them in series and then bridging them to the amp.polkaudio sound quality competitor since 2005
