Ok, question for any NAD C521BEE CDP owners...
ClemmonsHoo
Well, the stereo shop called today, and my C521BEE came in, so I took the C542 back in and picked mine up. :-(
I am none too happy. The 521 sounds fine (not as good as the 542), but the display does not match the display of the receiver at all. Instead of the background being black with whiteish characters like the receiver (and like the C542), the background is bright blue with greenish-yellowish characters. Is this right? I'll be bummed if it is.
Post edited by ClemmonsHoo on
I'm on the road right now, however my C521 matches the display on my C720 receiver. I'll have to check when I get home.
DougDKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
ClemmonsHoo wrote:Well, the stereo shop called today, and my C521BEE came in, so I took the C542 back in and picked mine up. :-(
I am none too happy. The 521 sounds fine (not as good as the 542), but the display does not match the display of the receiver at all. Instead of the background being black with whiteish characters like the receiver (and like the C542), the background is bright blue with greenish-yellowish characters. Is this right? I'll be bummed if it is.Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers. -
Maybe you can ask the dealer if you could have the 542 instead by paying the difference.
The dealer will let me pay the difference, but it's hard to swallow paying another $200.
As for the sound, when I first fired up the 521 it definitely sounded warmer than the 542. But after listening to it for a few hours now, I don't know, but I can't really tell that much difference.
I've tried to find pictures of the 521 online and from the ones I've found, the display looks like it should match. Mine looks like it's misadjusted or something, but there is no adjustment provided thru any of the user controls. I don't really want to open the case. -
The c542 has a VFL Display where as the 521bee has a EL Backlit Display...The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. -
which means it could have had the lights changed maybe? or are they leds.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Well, I took the 521 back to the shop and explained my issue. The guy said that he had not seen a display like mine had and that some of the units had an undocumented adjustment on the bottom of the case. Mine did not.
Knowing myself as well as do and that the display would bug the heck out of me, I opted to order a new C542. The sting of spending an extra $200 should wear off in a few weeks I guess.
Thanks for all of your replies.
