How can an amp be tested for function?
broguearcher
What options are there for testing the output of an amplifier in order to determine if it's functioning correctly? Simple AC/DC voltage meter?
I believe that my amplifier is passing on distortion to my sub. Can this be verified in some way?
Post edited by broguearcher on
hmm... theoretically, you could calculate the expected output voltage and then measure that, but that would be insanely difficult and have a huge error...
to check an AMP for distortion probably requires an oscilloscope, unfortunately... you may wish to ask your local community college if you can borrow one of theirs
have you narrowed the problem down to definitely the amp?It's not good, very fundamentally simply not good. - geolemon
I have not determined that the amp is for certain at fault but it seems likely. I've tried two different 10" MOMO subs on it and I am getting the same sound/result with them.neomagus00 wrote:hmm... theoretically, you could calculate the expected output voltage and then measure that, but that would be insanely difficult and have a huge error...
have you narrowed the problem down to definitely the amp? -
Is your system all tried and true (without previous distortion) before the addition of your sub amp in question?
It would be easier to pin down knowing what components you are using for everything, but if your amp in question is putting out clean power within the ideal range for your Momo 10", and your sub enclosure is within the specifications provided by Polk for that woofer, all should be well.
Some brands of amplifiers are known to be improperly rated as to power output, and some are known to provide a higher amount of distortion in the signal as well. If your amp runs out of headroom due to its design, or even if it cannot properly make its rated power due to faults in your vehicle's electrical system, distortion can result.
Ported and sealed sub enclosures will give different results with a given woofer, both with some trade-offs. A sealed box requires more power for higher output, and a ported box requires less but will not control the woofer as tightly across the whole spectrum of bass frequencies. An air leak in your enclosure can effect subwoofer output and sound quality as well. If anything is not ideal in the relationship between your sub, its enclosure, and the amplifier powering it, you can get some distortion in the mix.
Distortion can come from a number of things- the amp may be a good place to start, but by no means is it the only place to look. -
Actually, I read your other thread...
http://www.polkaudio.com/forums/showthread.php?t=40071
Don't bother to spend money testing this amplifier. It cannot do justice to any Polk Momo subwoofer. The amp will be the cause of your distortion.
While you may not like the answers (due to $$$), post a thread asking for suitable amps to power your new Momo 10" and then save up. -
Chances are that since the amp is cheap and low powered, youve got the gain set too high and are pushing it into clipping which is sending out the distorted signal to the sub and thats what youre hearing. Youd be much better off buying a proper amp that can make the proper power.polkaudio sound quality competitor since 2005
Time for an upgrade.........
Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
1996blackmax wrote:Time for an upgrade.........
oh, I know... completely agree. I was never looking for much of anything really in terms of performance. Just a little bass was fine...... now, I'm all wrapped up in this and want the best set up that I'm able to get for the money and I want the equipment to work right as well. -
id ditch that cheap amp and get a better one for the momo sub, the amp is your problemJohn Tyler Birch
home audio system:
Denon avr-1907
Sony dvd/cd changer 5 disc
nakamichi BX-100 tape deck
2 Polk Audio monitor 70's
Velodyne DPS-12 subwoofer
RCA TV
NAK 600 tape deck
Monster power line conditioning power center -
98thumpin wrote:id ditch that cheap amp and get a better one for the momo sub, the amp is your problem
agreed..... I'm working on that issue at the moment. -
Hey I have a polk c500.1 mono sub amp.. very very clean and in good shape. only 6 month's old. I'd sell it for $300 if you want.. Cheaper then buying it new.88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
Premier 860mp 140 & 200 amp altenator
MMC6500 driven vy c300.2
MMC690 driven by c300.2
2-MM2104's driven by c500.1 -
You can buy em new for less than $300.....if you know what you are doing.
$200 would be a deal! -
Actually Lightning Audio Strike and Storm series amplifiers aren't bad at all...they're quite nice in fact. Very reliable, extremely potent and robust. A bit on the warm side in my opinion, but most come with built in fans...
The Bolt series isn't really worth much though -- they're 'Best Buy' / 'Walmart' type amps... they're not junk... but they're not the creme de le creme by any means...
What I'm trying to say is that - normally driven within its means - a Bolt amp should not produce any more distortion than any other respectable amplifier. I agree with previous posters that you are probably driving this amp well beyond its rated output power and thus trying to get blood from a stone, throwing it into clipping like crazy.The Artist formerly known as PoweredByDodge
