Running a DVC sub on ONE coil???
What would happen to a DVC coil sub if you decided to only connect the one coil and use it that way?
Post edited by broguearcher on
    VR3 Posts: 29,626
    edited April 2006
    Itd make sound :)
  • broguearcher
    broguearcher Posts: 28
    edited April 2006
    :D:D:D:D
    yes, I do hope it would make sound!! .... however, would it make sound safely and without damage to itself?
    Thanks.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2006
    Yes.
  • kingkip
    kingkip Posts: 401
    edited April 2006
    Remember though that you should derate the max amp power by about 25% or so. Or just be careful with how much juice you put through them. Also your output will decrease by about 3db. You can also hook up a variable resistor to the second coil and change the Qts of the driver.
    This link tells you how http://www.adireaudio.com/Files/TechPapers/RDOOperation.pdf
    There are two ways to argue with women. Both of them are wrong.
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    You could always hook the sub coils up in series.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
