Signature Reference vs DB Series
polk_audio_lsi
polk_audio_lsi Posts: 71
edited April 2006 in Car Audio & Electronics
Polk Audio only makes 6 1/2" component's for the Signature Reference. I'm thinking about getting them for my 2000 Monte Carlo. Would it be a terrible difference if I would get MOMO 6"x9"s? Or if I would do Signature Reference 6 1/2" components in the front and the back would a Polk MOMO 2 channel amp pushing 200 watts per channel be able to power them properly.
I've read reviews and Polk's saying it's like having LSi home speakers in your car. First of all I was thinking about doing all DB series cause I've heard they're 6"x9"s and I think they sound really good. What would you all recommend me do?
You've probably seen me on several posts obsessing about Home Theater. Well I've finally came to a conclusion what I want and I'm just gonna build it piece-by-piece one-at-a-time.
CURRENT SYSTEM:
(TV) Sylvania 24"
(DVD Player) LG DVF 9900
Sony Playstation 2
(Receiver) Onkyo TX-SR503
(Front Speakers) Polk Audio Monitor 40
(Center Channel) Polk Audio CS 1
(Surround) Paradigm Cinema ADP [Dipole] (On top of Polk Audio Monitor 40)
(Subs) Pioneer CS-G9001 (Bi-wired with Fronts subwoofers only working layed down up against back of couch)
Monster Fiber Optic Cable (DVD Player to Receiver), Monster speaker wire
Post edited by polk_audio_lsi on
  • jderdock
    jderdock Posts: 131
    edited April 2006
    I'm confused. Crutchfield says the 2000 Monte Carlo has 6 1/2"s up front and in the back. What's the issue?
    Rega P3 > Parasound Zphono > NAD C320BEE > Polk LSi 15
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    and you're comparing the top of the line components to a middle of the line coaxially mounted "by nine?" Let's compare your monte to a kia. Same difference.
  • brettw22
    brettw22 Posts: 7,623
    edited April 2006
    There's nothing wrong with mounting the SR's coaxially if you'd like, but the SR's are a much better speaker in build quality compared to that of the DB. That's not to say that you won't like the DB........it's just whether or not you want to spend the extra coin on the SR's
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited April 2006
    Save your cash, no need to put SR's in the back. If you want rear fill get a set of coaxials.
    What will the rest of the system be composed of?
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    edited April 2006
    The Momo 2 channel amp makes 150 watts per channel.
    The Signature Reference line is Polks high end line and designed to compete with the best speakers on the market at half the price. The DB line is their entry level line and cant hold a candle to the SR's.
  • polk_audio_lsi
    edited April 2006
    OK 150 watts per channel not 200 my bad. Well, will a 2 channel Polk amp be enough to properly power them then, if I would get components for the front and rears? Or do you think I should just get components up front and coaxial's in back. And if that case should I get DB series or MOMO series? And then another thing, what about amp cuz Polk Audio don't offer much on amps. But then again I'm TRYING to keep things just Polk. I find it much better end results when you stick with one series / brand.
    I'm thinking this:
    Alpine CDA-9853
    Polk RS 6 1/2 (door)
    Polk ??? (rear)
    Polk DB212-2 (sub)
    2 Polk C500.1 monoblock subs (one for each woofer)
    C300.2 2-channel amp (for fronts and rears)
    CURRENT SYSTEM:
    (TV) Sylvania 24"
    Sony Playstation 2
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2006
    I'd say a 300.2 for the SRs in front, with coaxial momo or db (momo preferably, but depends on your budget) in the rear... maybe a 300.2 to power them, though that's overkill... if you're thinking of adding a small sub in the future, maybe a 400.4 for the rears, with 2 channels left over to be bridged to the sub...
  • 98thumpin
    98thumpin Posts: 649
    edited April 2006
    id go with neos setup sound good.
    John Tyler Birch
    home audio system:
    Denon avr-1907
    Sony dvd/cd changer 5 disc
    nakamichi BX-100 tape deck
    2 Polk Audio monitor 70's
    Velodyne DPS-12 subwoofer
    RCA TV
    NAK 600 tape deck
    Monster power line conditioning power center
