Can sun/ dust damanage your speakers/ electronics?
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2006
    wallstreet wrote:
    Amen brother!
    I can testify... UV... that's why people should use Armour All.... or Coppertone... on their MW's.
    Walter, where you been?
    More later,
    Tour...
    Vox Copuli
  • wallstreet
    wallstreet Posts: 1,405
    edited April 2006
    Y'all aren't playing your speakers loud enough if there is dust collecting on them.
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited April 2006
    heiney9 wrote:
    Ever heard of Ultraviolet rays (UV) (and other components) that's what's damaging in sunlight. Your analogy of indoor light to sunlight is completely wrong. If that were the case our skin wouldn't get tan/burned when we went outside in the sun. Heat can be an issue (beyond normal temps/like those in an oven) but humidity will do more damage than heat.
    Geez, where do people get this stuff :confused:
    Yes of course I have. But there is a difference between UV exposure if you leave your speakers outside in direct sunlight or indoors where the sunlight is indirect or filtered. In fact even if indoor direct sunlight would be hitting speakers directly, it would be either in the early morning or late evening so that the sun would be at a low enough angle to get through the side windows (as I believe this is when the poster said this was occuring). And at this time the sun itself is hitting the earth indirectly and is filtered by more of the atmosphere, decreasing UV rays, hence you dont get burned in the morning or evening. And thats why you dont get sunburns sitting on your couch. Unless your couch is outside :)
    Thats why I qualified my statement by saying unless the speakers are within a foot or two of a window... I suppose a skylight would be bad though...
    Thanks for the belligerent tone in your response though :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
    heiney9 Posts: 25,447
    edited April 2006
    Sorry you took the response as belligerent. I stand by my assessment.
  • wallstreet
    edited April 2006
    I think belligerence is free on this board. Advice, however, will cost you.
  • Tour2ma
    edited April 2006
    Damn it, walter, I was gonna say that...
    Now all I've got is, "Could have skylights."
    More later,
    Tour...
    Vox Copuli
  • Zen Dragon
    Zen Dragon Posts: 501
    edited April 2006
    michael_w wrote:
    I never thought of getting an air purifier. I wonder if one of those fancy ionic purifiers would work as well.
    There are several extensive studies on the Ionic that show it does not do a good job of puifying the air. The Hepa's are much more efficient. Ionic is the largest seller of purifiers due to their superior advertising, kind of like Bose.
    Consumer reports tested a whole slew of purifiers and said the Ionic was only removing about 5% of the pollutants the Hepa types were. So Ionic sued them for slandering their product. Consumer reports ran the tests a second time with several proffessionals monitoring the results and got the same results on the tests as before.
    When the case got to court it was thrown out due to consumer reports meticulous documentation.
    If you want to go with an air purifier go with the hepa style. When you get into some of the better ones they have done a decent job of quieting them. I use a Kenmore (there are better) and it is just a soft white noise that you quickly forget you are hearing.
    Lots of info out there if you look for it.
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
