LC265i 's
edited March 2008 in Speakers
Has anyone installed the LC265i 's.
Did you use the performance enclosure.
Do you think they need a seperate sub for music listening.
Post edited by 1BigNovice on
Welcome!
    edited April 2006
    Hi Russell,
    Even though we exchanged some private messages on this subject, I thought I'd welcome you to Club Polk and bump your thread to try to stimulate others to respond to your question.
    As I mentioned, unless you have music tastes that require deep bass, the speaker's 43 hz lower -3 dB limit may be sufficient if average music is all you'll be listening to. If you're a big fan of organ music, well that's an other matter. ;)
    Like most speakers the LC265i's definately require a subwoofer for home theater, especially if you're an action movie fan.
    Larry
    edited April 2006
    Well the first question is are both your front channels LC265i's or are you using it as a front speaker only?
    My main room has three LC265i's and I found that as long as you set your amp/recever to have full sound in the front (the lack of sub feature) it sounds pretty good. Although I recently bought the PSW505 as a sub and I must say it does sound much better. So my sugestion is try it for a bit, you'll love it and then upgrade to a good sub and you'll love it even more.
    I haven't used the enclosure as I would have had to tear the walls down but I haven't found any problems with the sound.
    edited April 2006
    Russell,
    I have just recently installed 3 LC-265i (L/R/C) and two LC-80i (rears) in a newly finished basement. I used the enclousers for the front L/R. See http://www.polkaudio.com/forums/showcase/view.php?userid=69564
    Here is a specific picture of the enclousers: http://www.polkaudio.com/forums/showcase/closeup.php?userid=69564&pic=258_17_big.jpg
    I just received last week my new pre-amp Outlaw 990 and Amp Outlaw 7500. I am also hooking up the Outlaw LFM-1 subwoofer. I will be calibrating this weekend and repost then.
    edited March 2008
    Hi cewolcott,
    It's been a couple of years since your post, so I hope you catch this question. I am wondering how you like the LC265i speakers? I am about to install them in a newly remodeled family room, along with the LCi-RTS-C and LC80i back speakers, in a 5.1 configuration.
    I already put in the optional enclosure cabinets before the new drywall was installed. Now, I'm almost ready to install the speakers.
    My decision to put in-wall speakers (vs. traditional) was very sudden, and I had to move quickly to do research and decide what speakers to get. I am a fan of both Paradigm and Polk. Interestingly, Paradigm does not (at the current time) have an in-wall center speaker solution. I did not like the idea of putting Paradigm's LR speaker in horizontally.
    I liked Polk's center speaker design, so I went with Polk. And as I said, I chose the LCi-RTS-C because it comes with an enclosure, while the LCi-C does not. I thought it was prudent to get the best center speaker I could afford. But otherwise, I could not justify the additional $1200 for the RTS105's.
    My time window was so short, I had to overnight the enclosures before the drywall went up. :)
    I'm hoping I made a good decision. So this is just a gut check.
    Thanks.
    Speakers:
    . 5.2 surround config:
    . . . In-wall L & R Fronts and Center: Polk LC265i, LCi-RTS-C. In-ceiling L & R rears: Polk LC80i
    . . . Floor Subs: Polk DSWPro 500, Paradigm PDR-10
    . Zone B: very old pair of Polk M 5's
    . In Storage but still favored: Paradigm Monitors
    AVR:
    . Yamaha RX-V863
    Universal DVD:
    . Oppo DV-980H
    TV:
    . Sony Bravia XBR LCD 40" 720P (2005 vintage)
    . Comcast Cable, Motorola box
Welcome!
Welcome!
