Slimdevices Squeezebox
crazy
crazy Posts: 443
edited April 2006 in Electronics
Do anyone use Squeezebox from Slimdevices
http://www.slimdevices.com/
I am curious to know how good they sound? Sounds like a rather slick, inexpensive way to get music from your PC/Mac to your stereo.
I use Pandora quite a bit and I think it's an amazing way to hear new music.
Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes)
Post edited by crazy on
    heiney9 Posts: 25,217
    edited April 2006
    My brother uses a couple of Squeezeboxes in his house. One is hooked thru an outboard digital to analog converter the other uses the internal converter. They work quite well and he's very happy with them. The only down side is you have to know a bit about computing to get the network and everything hooked up to work properly. Anyone who has some computer understanding can get the job done though.
  • W WALDECKER
    W WALDECKER Posts: 900
    edited April 2006
    I heard a stock squeezebox at a friend of mines home in northern VA during a meeting of the Mid Atlantic Audiocircles group of which i am a founding member and it sounded phenominal. Red Wine Audio and Boulder cable offer modded versions of the Squeezebox and its power supply and they are gaining popularity to the point that many audiophiles/audio enthusiasts are ditching thier very expensive CD players in favor of this new technology. thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • Lsi9
    Lsi9 Posts: 616
    edited April 2006
    Heres an idea
    I use my xbox 360 to stream my music into my HT it transfers all my playlists from itunes and has alot of screen visualizers you can stream radio, photos and in some cases video, plus you play games in HD and 5.1
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
