Velodyne sms-1
dholmes
dholmes Posts: 1,136
Anyone have the Velodyne sms-1 eq? If so, does it work okay? Ive been looking at this for a while, just wanting to know if its worth the $$ thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2006
    Although a little more involved you could spend $99 on a Behringer Feedback Destroyer and run the free software, room EQ wizard, on your computer with the radio shack SPL meter. Although not as user friendly as the Velodyne, it's far cheaper and very effective. The BFD is very popular for EQ duties.
    There is also R-DES which may be cheaper then the sms-1.
    here is what the BFD and room EQ wizard are doing for my sub.
