Surrounf speaker placement height question...
maddevildog
I read that 6-7' from the floor is a normal height for surround speakers, my question is this, is the 6-7' to the bottom of the speaker? the top of the speaker? Thanks in advance, DJ
Post edited by maddevildog on
Tweeters should be 2-3' above the listeners ear level.
Because of room constrants,I have the bottom edge of our FX500i's six ft. from the floor.
They sound just fine from that position. -
ideally, your speakers should be aimed directly at your ears. rear in-wall speakers should be no more than 4' apart from each other directly over you, and your other speakers (front) should be where they hit your ear with no obstructions. many high end amps have a little mic that you can connect and it will measure the room height, walls, ambiance and etc for you so you don't have to measure it manually. a true lifesaving device.currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs -
Wrong. Surround speakers should not be aimed at your ears. Doing so will cause the surround channels to be very localized and that is the exact opposite of what a proper set up should do. If you can pinpoint where a surround sound effect is coming from you've done something very wrong.iworkfortweeter wrote:ideally, your speakers should be aimed directly at your ears. rear in-wall speakers should be no more than 4' apart from each other directly over you, and your other speakers (front) should be where they hit your ear with no obstructions. many high end amps have a little mic that you can connect and it will measure the room height, walls, ambiance and etc for you so you don't have to measure it manually. a true lifesaving device.
Using a built in mic and onboard setup program may not be what the doctor ordered. Read the following thread and you'll see what I mean.
http://www.polkaudio.com/forums/showthread.php?t=39650&highlight=calibration
If you want to set it up the old fashioned way...
http://www.audiophilia.com/hardware/spl.htm
Surround sound should be seamless and move around you 360 degrees.
Download and read the Polk Audio Home Theater handbook. It's a great place to start. -
School is in
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
aaharvel wrote:what kind of training do they provide at Tweeter again???
Must be getting ready to hit the FM.
That was my first thought. You don't want to know my second one.. hehehe Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
