rt5000 sub...
pjwinstalls
pjwinstalls Posts: 4
edited April 2006 in Speakers
I have the rt5000 system. I see a lot of people recommend on here to use a seperate sub... why is this? each second half of the rt3000 is a sub and the cs1000 has a sub also?
Philip
Post edited by pjwinstalls on
  • Skynut
    Skynut Posts: 2,967
    edited April 2006
    Welcome to the forum.
    the sub on the rt3000p's is only ok. If you get a better sub you will be amazed at the improvement.
    I am trying to get a better sub now and I want to use the rt3000 subs for the left and right speaker. I am hoping this will help the 2 chanel sound improve.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • bknauss
    bknauss Posts: 1,441
    edited April 2006
    The RT3000 sub is great for making the speakers truly full range, but I wouldn't use as a dedicated sub. Add a dedicated sub and you'll get the low low frequencies.
    Brian Knauss
    ex-Electrical Engineer for Polk
