setup with HDMI question...helppp
plattq45
HI, i'll make everything short to read.
*Harman Kardon 635 AVR (doesn't support HDMI)
*Sony HDMI upconvertion dvd player/SACD
*HDMI TV
question is that, a friend of mine want to take full advantage of the HDMI (TV/DVD) connection but the receiver is not supporting it,which he can't connect thru the receiver. how can he still have multichanels (5.1) audio while using HDMI cable from DVD to TV.
option 1****
DVD (HDMI) ----to--> TV and use the TV audio output --to--> Receiver?
Option 2****
DVD (HDMI)----to---> TV and...
DVD Optical cable---to--> Receiver?
will the above 2 option give him digital audio with the receiver while using HDMI cable from dvd direct to tv. if not can someone pls show a way to do it...thanks ahead for anyhelp.
*HDMI TV
option 1****
Option 2****
Post edited by plattq45 on
While HDMI supports both Video and Audio, I've found very few receivers and/or TVs that actually support both coming from 1 cable.
Having said that, option 2 should work fine. I've setup several systems at my old job that had HDMI going into the TV and Optical going into the Receiver. -
HDMI is currently a fairly new technology and only very high end equipment will be able to process this type of signal. some cable boxes and dvd players may not be able to correctly distinguish this type of signal being fed, and thus will not work, even if they do have a jack for the hdmi signal. i would use component cables and an optical as you have suggested, because in fact only to a very trained eye can you tell that one signal is better in quality than the other. i do home installs, and i can tell the difference, though on my equipment i do not use hdmi simply because it doesn't make that big of a difference. since your buddy already has one, use an optical in conjunction.. they are great.
good luck to ya.currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs -
What do you mean by "equipment"? If you mean receivers, than yeah most of the ones that include any HDMI support are very pricey but if you meant to include televisions in that category, than I wouldn't call that very high end as you can get TVs today for under $1,000 that include HDMI and are HD ready.iworkfortweeter wrote:HDMI is currently a fairly new technology and only very high end equipment will be able to process this type of signal.
HDMI is a standard and products that include the HDMI input/output have to meet specific specifications. Also, I have never seen a cable box or DVD player that included an HDMI input (not sure why you'd want to fed that kind of signal into those components like you mention).iworkfortweeter wrote:some cable boxes and dvd players may not be able to correctly distinguish this type of signal being fed, and thus will not work, even if they do have a jack for the hdmi signal.
Don't forget, HDMI is backwards compatable with DVI (HDMI A with single-link DVI and HDMI B with dual-link DVI). Any box that can drive a DVI monitor can also drive an HDMI monitor and vice versa.
He didn't suggest using component cables and optical. He suggested using HDMI and optical.iworkfortweeter wrote:i would use component cables and an optical as you have suggested, because in fact only to a very trained eye can you tell that one signal is better in quality than the other.
You're right though; component cables would be fine. However DVI and HDMI give much better results at higher resolutions (around 1080p or so) so going with HDMI now would be preparing more for the future. Plus, Blue-Ray and HD-DVDs are coming out this year and they'll be able to get to those high resolutions. -
plattq45 wrote:HI, i'll make everything short to read.
*HDMI TV
option 1****
Option 2****
Only HDMI 1.3 or greater will passthrough SACD. I have yet to see any HDMI 1.3 on receivers.Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5 -
According to the 1.2 specification, they added support for SACD. Also, on the HDMI website, it only shows 1.2a specification has been released so I would be surprised to see anything with 1.3.just_visiting wrote:Only HDMI 1.3 or greater will passthrough SACD. I have yet to see any HDMI 1.3 on receivers.
Or am I totally off base here?
