dayton or Ascendant compare to Polk
jakelm
jakelm Posts: 4,081
edited April 2006 in DIY, Mods & Tweaks
Im thinking of building 2 new inclosers. My Hafler DH-200 will be the amp. My question is, should I build one of the new inclosers with my current Polk 10" sub that is coming out of the PSW10 or should I consider replacing with another? Maybe Dayton or Ascendant. The other incloser will be the either the Dayton or the Ascendant to replace the MTX sw2. I was just wondering since I dont have the specs on the Polk woofer itself. I do know both Dayton and Ascendant have much bigger magnets and can handle much higher wattage. But I dont know how the quality or sound quality of Polk subs compared to these 2 other manufactures.
Bothe boxes will be conciderably larger. the 12" will be 4.2 cu ft, and the 10" will be 3.5 cu ft. So the air space will increase considerably.
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • maxima
    maxima Posts: 143
    edited April 2006
    Are you talking sealed or ported? These box sizes would be on the large size if sealed is your preference.
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    Ported.. and both downfireing, I havent desided wether to go with downfiring ports or side firing
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • burdette
    burdette Posts: 1,194
    edited April 2006
    Without having the T/S parameters for the Polk driver, you'd be in risky territory building a new, DIFFERENT, enclosure. The driver might perform fine in different alignments - Polk chose the one it did to meet whatever design criteria were in place. But again, without the specs.... You could measure or have the specs measured if you really wanted to. My gut reaction is don't bother.
    If you check out the Parts Express forum, you'll find a lot of information on the Dayton drivers and different enclosures people have used. There are a LOT of speaker-building sites on the web - a lot of information out there. I bet you could find several successful designs for whatever driver you select.
  • Zen Dragon
    Zen Dragon Posts: 501
    edited April 2006
    You'd probably be better off with a better driver. There are many good choices of driver out there that should outperform the stock Polk driver. If you are going to design the new sub yourself why not improve on it in every way possible.
    If you aren't aware of it here is a great resource with lots of info on building your own sub.
    http://www.diysubwoofers.org/
    This page has lots of good info also
    http://www.diyaudio.com/
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    I am a member of www.diyaudio.com But I wanted to ask here since this is a Polk forum.
    Polk does not have the t\s specs for this driver. So I was wondering if anyone had any experience modding out the cabinet for a Polk sub driver.
    Both Dayton (partsexpess) and Ascendant audio have specs, but if the Polk would perform well under different condition, I wont need to purchase a driver.
    I guess I'll just build the cabinet and try the Polk out to see. Even to know what wattage it could handle would be alittle helpfull. But if it distorts with the Hafler in the new cabinet, I guess that would tell me alot.
    It will be one of those "try and see" type of situations.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2006
    The dayton or AA drivers will far outclass the polk driver. The Polk driver was likely designed to be in the polk box and paired with the polk amp because they likely have some EQ running through it somewhere. I don't think it would be worth the effort. Sell the Polk sub to fund the DIY sub, it will be worth it.
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    Will do Try. I figured it as much. I hate to get rid of anything Polk. But knowing Polk, I think they understand when someone replaces their sub....lol..:eek:
    No offence Polk.:D
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    Hey what happend to my sig?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited April 2006
    Oh there it is,
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
