please reply!
iworkfortweeter
ive installed a c400.4 momo amp which is powering two 6.5 momo speakers, along with two tweeters. the problem im running into is i am only getting sound from the tweeters. there is no mid-bass at ALL coming from this system, and i HAVE tried reversing the wires. please get at me if you know what the dilly is.
currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs
Not to be insulting, but first thing make sure you have the proper wires coming from the crossover wired properly. If you stick the tweeters wires on the mid you aint gonna hear too much.
Try running speaker wire directly from the amp to the mid, bypassing the crossover. If the mid works then you know youre crossover is the culprit.
Other thing to check, make sure the crossovers are set properly on the amp.polkaudio sound quality competitor since 2005
