Spades or Bananas w/jumpers? (LSi15)
jderdock
jderdock Posts: 131
edited April 2006 in 2 Channel Audio
I started putting together some new speaker cabling last night using Canare 4S11 starquad, techflex and some heat-shrink tubing.
I'm trying to decide on how I'd like to terminate these. I'm still running the little brass jumper thingy on my LSi's and figured I'd try replacing these while I had some spare Canare 4S11 laying around.
My question:
Do I terminate my speaker cables with spades and make a banana-to-banana jumper?
Do I terminate my speaker cables with bananas and make a spade-to-spade jumper?
Or do I terminate my speaker cables with spades AND use spade-to-spade jumpers?
Thanks in advance, and attached are photos of my progress (still needs a little heat shrink here, some loom there and termination:
Rega P3 > Parasound Zphono > NAD C320BEE > Polk LSi 15
Post edited by jderdock on
  • organ
    organ Posts: 4,969
    edited April 2006
    Welcome to Club Polk!
    Nice cables. Go bare wire. Spades/banannas just makes life easier for swapping cables. Bare wire is a better contact. Try bi-wiring instead of using jumpers.
  • jderdock
    jderdock Posts: 131
    edited April 2006
    Thanks for the reply :)
    I'm definitley going to be terminating them. I've always run bare wire and I always seem to end up with nasty ends on my cables and I'd rather avoid that this time around.
    Why had I not thought of bi-wiring with this set? The starquad seems ideal for this application....
    hmmm
  • organ
    organ Posts: 4,969
    edited April 2006
    Yeah, you got a pair of 'bi-wire ready' cables there.
    Ok, then go spades. They give you a big surface area and you can really tighten the binding posts. If you like banannas, find some that can fit real tight.
    Good luck
    F1nut Posts: 51,794
    edited April 2006
    It doesn't make a bean hill of difference between spades and bananas. You nor anyone else can tell the difference sound wise. Bare wire isn't any better, again no one can tell the difference except when the copper oxidizes with time.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2006
    Bare wire will provide the best contact, with least resistance. Less metal, less terminations. If you don't bi-wire, I prefer spades for the best fit from amp to speaker (compression), and nanners for the jumper.
    Cheers,
    Russ
    F1nut Posts: 51,794
    edited April 2006
    Not to argue or anything, just curious. Can you tell a difference in sound quailty, Russ?
  • jderdock
    jderdock Posts: 131
    edited April 2006
    I'm far from an expert on the topic, but wouldn't that depend on the style of jack that a speaker or amp uses? I've often found myself plugging bare wire into a speaker's input and thinking to myself: "I bet the connection between this bare wire and a specifically designed spade/banana would be more efficient than the bare wire straight to this speaker jack that doesn't seem optimally designed for a piece of bare wire".
