outlaw audio pre/pro 990
crmfmly
crmfmly Posts: 34
edited April 2006 in Speakers
I'm thinking about buying an Outlaw Audio pre/pro 990 and the website says it has 2-channel subwoofer offset. Does that mean I can hook up 2 subs to it? Or can I only hook up one sub. Can somebody tell me what that means?
Receiver: Onkyo TX-SR503 75 x 7
Fronts: Polk Audio Monitor 40 (Triangled toward "me" Bi-wired)
Center: Polk Audio CS1
Surrounds: Paradigm Cinema ADP (At corners above couch about 3 feet)
Subwoofer: Velodyne VRP-1200
Post edited by crmfmly on
  • crmfmly
    crmfmly Posts: 34
    edited April 2006
    could somebody also tell me how I connect the outlaw audio 990 to the 7700?
  • crmfmly
    crmfmly Posts: 34
    edited April 2006
    I'm gettin the Polk Audio LSi series and an Outlaw Audio 990 pre/pro and an Outlaw Audio 7700 amp. What all should I run on the amp? All of it? Just the front speakers? What?
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2006
    The amp connects to the preamp via 7 rca interconnects, very simple to do. Your speakers (all seven of them) then connect to the amp.
    The 990 can send an LFE signal to two seperate subs, again a very simple connection.
  • sickicw
    sickicw Posts: 456
    edited April 2006
    If you are looking into that pre amp, I would also consider the Sherwood Newcastle P-965. It is similar to the outlaw, but has auto eq. Actually outlaw is using the sherwood design and reselling it as their own.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • jrlouie
    jrlouie Posts: 462
    edited April 2006
    The 2-channel subwoofer offset is a function that allows you to decrease the subwoofer level output for only when you are listening to 2-channel stereo. They have this since some people find the subwoofer to be too loud when listening in stereo.
    But, it does have 2 subwoofer outputs, both are the same exact signal (mono), just allows you to easily hookup 2 subs.
    You can also hook up the 990 via balanced XLR connections, which I personally recommend, but not needed.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2006
    Then he might as well get the Outlaw & save himself $400.00. He can pickup a Radio Shack spl meter & do that himself.
  • Holydoc
    Holydoc Posts: 1,048
    edited April 2006
    Another nice thing about the 990/7700 combo is that you can connect them together with balanced interconnects rather than straight RCA cables. This should help eliminate any problems with hum or cable/power interference.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2006
    I agree somewhat. I have the P-965 and I have not gotten the EQ added because I have read that not even truly Nolan can get rid of the bugs in it. I think it's more important to treat them room correctly first anyhoo.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
