Def Tech PowerMonitors
dipiazza
Im looking to get a small 2CH system for my dorm room. I was considering possibly getting the Def Tech PowerMonitor 500 or 700 speakers. Since i listen to mostly rock, i like to have a little more bass then i can usually get out of a bookshelf. Has anyone ever heard the powermonitor series?
http://www.definitivetech.com/loudspeakers/powermonitor/powermonitor.html#pm500
Also, what would you consider for powering them. Id like to get a small integrated to keep it simple. But i know alot of integrateds dont have LFE out. Can i still get the powerd sub to work with out using the LFE in on the speaker?
Thanks for the help!
Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
HT Setup
TV: Vizio VX32L
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
2CH Setup
Headphones
Other Stuff in Use
Post edited by dipiazza on
I am going to live in a small room as well and was considering these for next year, and even though I have a dealer semi close by, have only heard the mythos. Lots of people like the mythos but I don't. I won't judge this line but as I can agree with you that most people like def tech for rock and movies.
A nice integrated, might want to give a price range. I just read a sterophile review on this one from outlaw which they loved - http://www.outlawaudio.com/products/rr2150.html
I'll be moving from my current set up (look below in sig) to hopefully jm labs line, but I'll be doing a few months of research and listening before i buy.
The energy C-3 from audioadvisor is a great cheap one that I use on my computer. It has plenty of low extension, not as much as that power monitor, but for the savings you could buy a decent sub.
http://audioadvisor.com/store/productdetail.asp?sku=ENERC3B
Hope this helps,
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
