Primer on Pre-amp/Processors Needed
DForeman
I've noticed in the various forums here that for those who have a Denon receiver/external amp combo, the receiver is a 3800 model or higher.
I have a Denon 2106 AVR and recently purchased an Outlaw 7500 amp (thanks to the great advice given from you all).
I am wondering if there is something preamp specific in the Denon 3800 or higher models that are not in the lower ones.
Parasound P5 Pre
Marantz AV 7703 Pre/Pro
Outlaw 7500 Amp
Marantz SA14s1 SACD/CD
Rega Planar 2 TT
Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
Oppo BDP-103
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103
Post edited by DForeman on
hard to say specifics in terms of build. I dont even know if there is a difference in the Denon recievers you mentioned. It might be sonically a little better if there is a difference in build quality or whatnot.
In case you r considering an upgrade, I wouldnt upgrade to another reciever as a pre/pro. I would head right to the Outlaw 990 pre pro. with the reciever route, your paying for an amp section your not going to useLiving Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
nothing specific for me, i bought the denon 3802 thinking it was going to be all that i needed and then i bought the adcom to see what all the hype was about adding an external amp. i would just look at the feature list, if there are features on the 3800 or up that you need, go with that, otherwise i am sure your 2106 is probably all you need.
Thanks. I will in fact be upgrading eventually -- probably to the Outlaw 990. It seems like a good "mate" for the 7500 amp.
I've read here that upgrading to the 990 improves sound quality greatly --
meaning a good preamp is important. That's why I was just wondering if the
Denon receivers differed on the preamp side as well as the amplifier.Parasound P5 Pre
Outlaw 7500 Amp
Rega Planar 2 TT
Oppo BDP-103 -
i have not heard the denon 2100 series so i really could not comment on that but your plan sounds like a good one. i think the whole avr/power amp combo is really a used best as a way to save some money for a move to a dedicated pre-amp. at least that is what i am doing...
