lsi and home theatre
Midnite Mick
What do you guys actually think of the lsi's for home theatre? I am very happy with them musically but find that they lack in the home theatre department. Am I the only one? (maybe my center is to new still and hasn't opened up yet). Looking for your thoughts.
Mike
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Consonance cd120T
Usher CP 6311
Post edited by Midnite Mick on
What are you powering them with?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Powering the 7's with exernla amps and an SVS and I couldn't be happier.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
I am using the Nuforce ref 9 on the mains and ref 8 on surrounds and center. The eights may not be enough for the center now that you mention it. But those 9's are more dynamic power than the lsi's can handle.
Maybe my view is a little skewed as I heard those amps on some Ushers watching King Kong the other night. The sound was unbelievably good. Having said that I wasn't crazy about the tone of the Ushers for music though. A little cold and edgy.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
I love my LSi's for Home Theater. (I use my system for about 90% HT)
The sound is great. I do need a better pre-amp (an issue I hope to solve as my next upgrade.) In all fairness, I do not have alot of audiophile friends, and do not have much to compare them to. (I have never heard the RTi's in a well set up Home Theater.)
For what I have paid for my speakers and amplification I am VERY happy with my purchases and could not think of anything else I could have purchased for the price that would get me close to this level of performance. (I purchased both my amp and LSi's used)
My HT sounds awesome with my LSIs but that could also be because they are being super powered by my gear.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
her is from the web site for the ref 9...
Power/Load
8 ohm 160W
4 ohm 300W
2 ohm 350W
...not bad, but not the greatest of specs. my setup can double the power all the way down to 1 ohm. They are very dynamic when i put in a movie that has a good dynamic range for the soundtrack... Some people prefer the sound of the lsi9 over the lsic. I think wingnut uses a lsi9 as a center. The lsi9 shoulds much different from the center. try to switch them around and see what i mean.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
In what way do you find them lacking in Home Theater? Detail, clarity, impact, ???
What sub and electronics are you using with your system. For impact and slam, the sub is VERY important for home theater.
Just curious.
I am finding the soundstage to be a little smallish. Also, maybe a little brighter tweeter is probably better for home theatre. One other problem may be my source. Waiting for the new formats to come out and settle before I upgrade that however.
Why do the lsic sound different than an lsi9? I don't have the 9's to compare. They have the exact same specs (crossovers, sensitivity, drivers). The only difference is they don't go quite as low but that seems quite insignificant. Maybe due to cabinet size.
Consonance cd120T
Usher CP 6311
it is due to the cabinet design, and they use different crossovers. The specs for the crossovers are the same, but they are actually different units.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Can somebody try to explain the difference in the sound between the lsi9 and lsic?Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Also those numbers on the Nuforce amps are a bit misleading. They are going to be more powerful than the same numbers of a ss amplifier. This is because they have less than .05 distortion at any volume level. Clipping is no issue at all. I have heard them wide open on gear (4 ohm Usher speakers) for an extended period of time. They were fantastic!
Consonance cd120T
Usher CP 6311
there are theads on the lsi9 vs lsic. here are a few..
http://www.polkaudio.com/forums/showthread.php?t=34436&highlight=lsic+center
http://www.polkaudio.com/forums/showthread.php?t=27175&highlight=lsic+centerSpeakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
I think one of the keys to LSI is just giving them enough power. I'm still fiddling with my system right now but I went to Frys today to hear what their setup was like and I was thoroughly shocked. They were powering them with a plain old 125 watt Onkyo receiver. The sound was so muddy compared to the setup at home with my Earthquake amp. The LSI's really like to have about 300watts if you can provide it.Home Theater In Progress
Samsung 4272
Denon 3910 Universal Player
Anthem AVM-20
Anthem Statement A5
Fronts LSI-25
Center LSI-C
Surround LSI-FX
Getting closer to complete!:D -
Midnite Mick wrote:Also those numbers on the Nuforce amps are a bit misleading. They are going to be more powerful than the same numbers of a ss amplifier. This is because they have less than .05 distortion at any volume level. Clipping is no issue at all. I have heard them wide open on gear (4 ohm Usher speakers) for an extended period of time. They were fantastic!
Mike
Not sure what you mean by that statement. There is no amplifier that can run "wide open" without clipping. I must just be misunderstanding your statement. Also you mentioned the Lsi's not having an adequate soundstage. Look at placement and associated source. You rarely hear about the Lsi's not having a good soundstage.
FWIW
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
