Can Adcom GFA 5500 ,,,,,,
StarlightWk
StarlightWk Posts: 33
edited April 2006 in Vintage Speakers
Hi guys,
Need some info on Adcom gfa 5500, is it of common ground which is needed to
to power SDA SRS 1.2 ? Thanks in advance .
Post edited by StarlightWk on
    heiney9 Posts: 25,203
    edited April 2006
    Hi guys,
    It is not common ground as the transformer has secondary windings. There has been some discussion around here about wether the negative terminals can be connected to each other, I don't recall the answer. Use the search function as the answer is here somewhere as it's been discussed within the last 6 months. Or you could call Adcom and ask them, it may take a while to get a response however.
    edited April 2006
  • StarlightWk
    edited April 2006
    Thanks H9 for the qucik reply . Another question, do u know when were SDA SRS made its debut in the market ? There is a pair for sale in my area, tweeters
    are the silver dome / not the black ones, that I am having now.
  • read-alot
    read-alot Posts: 812
    edited April 2006
    Here you go http://www.polksda.com/list.shtml
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
