Harman Kardon--Different Modes for Different Folks
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited April 2006 in Electronics
Anyone with an HK receiver notice a slight decibal gain when going from stereo mode to Dolby Pro Logic II or one of the other surround modes -- when running with only two front speaks connected? You'd think with the extra wattage the AVR supposedly puts out in stereo mode vs all other surround modes (in the case of the 240 it's 65 watts vs 50), it would work the other way around?:confused: The only things I can think of is the possibility of "doublestacking" rear and front channel signals when forcing surround sound into two-channel, or possibly just a good ol' fashioned quirk of the DSP and its associated tone controls.
The sound quality isn't improved per se (in that there doesn't seem to be any more headroom). In fact, it sounds better to my ears in stereo mode (as it should). Just curious about the decibal gain is all.
Post edited by zombie boy 2000 on
  • mldennison
    mldennison Posts: 307
    edited April 2006
    may some sort of gain is introduced when it goes through the pro logic decoder???
  • Willow
    Willow Posts: 11,224
    edited April 2006
    It could also be the fact that digital or a prologic sound may be more compressed. The same thing goes on when I watch HDtv then a commercial comes on which is not HD it's much louder.
    BTW I own a HK as well, my Yammie did the same.
  • zombie boy 2000
    edited April 2006
    Could be.... just odd you know?
    Kind of goes against common sense (i.e. more watts = higher volume).
    In other words, to be downshifting (so to speak) from 65 watts into two channels to 50 wpc in surround mode would lead one to believe that the volume would decrease not increase.
  • aaharvel
    aaharvel Posts: 4,489
    edited April 2006
    the dolby v.s. (virtual speaker) modes are noticeably louder. The Dolby VS Wide 5.1 mode is louder than regular Dolby Digital. It's probably normal.
    I use the default audio setting for all digital sources, and Logic-7 for all analog.
    and btw the human ear is not likely going to hear a difference in "volume" between 65 and 50 watts unless you're super-sensitive and the volume is turned way up. Then you're talking head-room issues. There's only a 1db. difference.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • zombie boy 2000
    edited April 2006
    figured as much Andrew
    thanks for the info:)
