Anthem mca50 powering Polk FXi3?
just_visiting
Would I blow my Fxi3, which is 150w max power handling, if I power it with an Anthem MCA50 amp which is a 180w X5? Thanks alot.
Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
Post edited by just_visiting on
It's possible, but then you could blow your fxi's with many amps whether or not they put out 150 watts.
Just drive them reasonably (don't push them super hard or if you hear them struggle at least back off a little) and you should be fine with any amp you get for them.
Try not to get caught up too much in wattage. For normal listening levels you probably only use a watt or two anyways. -
I'm currently running the Fxi3 off a Denon 3805. My volume is usually around -18 to -30.Display: Sony XBR3 46"
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
Speakers: Paradigm Reference Studio 20 v.5 -
as long as you cant hear the speaker breaking up or struggling, you'll be fine.
remember, its actually easier to blow a speaker underpowering it than overpowering it.Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
if you got that anthem driving rears, what do you got driving the restLiving Room 2 Channel -
ohskigod wrote:if you got that anthem driving rears, what do you got driving the rest
Right now I have the Anthem MCA50 driving all 5 speakers. Planning to add a 2channel amp down the road if I decide to setup a 7 channel system. I wasn't sure if it will blow my rears/surrounds. I'm using a Denon 3805.Display: Sony XBR3 46"
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
your all good bud, cant see you having problems.Living Room 2 Channel -
ohskigod wrote:your all good bud, cant see you having problems.
Thanks alot for your help. When I move into my new home, I'll be setting up a 7.1 system by adding in a set of RTi6 for the rears.
Also 1 more question, is it a good option to use a set of towers for the rears? I might use the RTi8 as rears and get a set of RTi10/12 for the fronts.Display: Sony XBR3 46"
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
thats not a bad plan, plenty of people run tower surrounds. gives you something to do with the 8's if you upgrade your fronts to 10's or 12's. saves you the trouble of buying stands, as long as you have the floorplan figured out, i.e. where you can put the towers and not have the wife want to stab you in the eyeballs (if WAF is a factor for you) then go get em, its not a bad idea at all.Living Room 2 Channel -
ohskigod wrote:thats not a bad plan, plenty of people run tower surrounds. gives you something to do with the 8's if you upgrade your fronts to 10's or 12's. saves you the trouble of buying stands, as long as you have the floorplan figured out, i.e. where you can put the towers and not have the wife want to stab you in the eyeballs (if WAF is a factor for you) then go get em, its not a bad idea at all.
Would using a pair of LSI15 for the fronts timbre match the RTi8/Csi5/FXi3?Display: Sony XBR3 46"
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
just_visiting wrote:Would using a pair of LSI15 for the fronts timbre match the RTi8/Csi5/FXi3?
no, but your an LSiC away from having a timbre matched front soundstage, matching to surrounds is not nearly as important as having the fronts match up
your Anthem should power the LSi15's no sweat too. you can let it fly without the LSiC for a while, thats what god created later upgrades for.
of course, you can run the LSi15's in 2 channel a bit to really appreciate them. they are a great speaker, and if they are in your budget, I say snag it. Unlike others looking to step to the LSiC, you allready have the amplification issue down pat.Living Room 2 Channel -
actually, after further thought, you might consider selling the RTi8's then getting the LSiC with the funds. I would venture a guess that LSi15 mains with a LSiC center and the FXi surrounds in a 5.1 set up would be a little more rewarding than 7.0 with the RTi8's and no LSiC center. for many, this wouldnt be the casebecause of amplification (I'd tell you to stick with RTi if you had a reciever), but, as I said, you dont have that problem with the Anthem. plug LSi's into that thing all day and you'll be A OKLiving Room 2 Channel -
