Best Reciever for RM6005?
vipari
vipari Posts: 10
edited February 2009 in Electronics
Please help me choose the best combination for a Rm6005
Post edited by vipari on
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    Denon AVR-5805
    lol seriously, what features do you need?
  • *Seby*-Polk-
    *Seby*-Polk- Posts: 375
    edited April 2006
    uhhhhh..there are a lot of good receivers for your speakers....
    Choose the right for your ears. Listen Denon, Yamaha, HK ......;)
    My current new system (step by step :D)
    A/V Receiver: YAMAHA RX-V657
    DVD Player: YAMAHA DVD-S657
    Main Towers: polkaudio® Monitor 50
    Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² )
  • shawn474
    shawn474 Posts: 3,052
    edited April 2006
    To be quite honest, the rm6005 is about the entriest (is that a word) level speaker package that Polk offers. I doubt, IMHO, that you would get much benefit out of spending more money on a higher priced receiver to get these to sound better. Unless you plan to eventually upgrade the speakers at a later date, I would think you could stay with the lower end Denon, HK or even get Yammie, Onkyo, etc. and have a nice sounding system at a much more reasonable price.
    I have the RM6005 package, but wasn't too happy with the center channel. I would recommend upgrading the center channel at the very least. I have since installed that system into my parents house and it does just fine considering they don't listen to it as often as I do.
    Congrats on the purchase.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • Johnnybass
    Johnnybass Posts: 39
    What would you recommend for the center specker upgraid?? i have the 6005 hooked up to a Onkyo TXSR303.
    Thanks JB
  • comfortablycurt
    comfortablycurt Posts: 6,745
    A good low budget receiver you might want to look into is the Onkyo TX-SR606. It packs in a lot of the features that higher end receivers have, such as the most up to date sound codecs, 4 HDMI in's and 1 HDMI out, dual zone capability...But leaves out some of the frills to keep the price down. It's biggest drawback is the lack of pre-amp outputs, so connection of an external amp is impossible. That's something to keep in mind if you plan on upgrading your system with external amplifiers in the future. I own a 606 myself, and I couldn't be happier with it. They can be had for around 300-350 dollars. IMO it's the best receiver in that price point you can get.
    A good center you might want to look into is one of the RTi series centers. Either the CSi A4 or CSi A6 would work well. You could also look into the CSi3 or the CSi5, which are the older versions of the same center channels, if you wanted to save a little coin.
    Going that route, you might eventually want to upgrade your front channels as well, with some of the RTi series bookshelves or floorstanders. That would give you a really solid front soundstage, and would give you dramatic improvements in sound quality. You've gotta work within your budget and space constraints though of course.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
