Monitor 60 w/ SVS?
Hi, i was looking at the Rti series for my next HT/Music and then i stumble across the Monitor 60 for a great price, so my question is that will the Monitor 60 blends with an SVS plus? i can save like $200+ if i go with the monitor60 instead of the RTi series(just trying to save what i can )
i already have an H/K AVR 635
Anyone here experienced with the MOnitor60 please let me know how they sound.
Thanks ahead...
Thanks ahead...
Post edited by Polkyyy on
The Monitor 60 speakers sounds GREAT. IMHO this towers sound more balanced than Monitor 70's. If you buy a sub with a pair of 60's ... you're in heaven
I bought the 50's for the price (Here, MSRP: U$S 560) compared to U$S 800 (M60) and U$S 1,120 (M70). Very happy with the sound quality. But the 60's sounds more "powerful". Highly recommended !!!!
ByeMy current new system (step by step )
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
How would anyone compare the m60 to Rti6 or Rti8, i tried the SEARCH button and didn't find any great result, it is worth the $200+ the different?
Rti8 vs M60(save some $$) -
Polkyyy, do you have any chance to listen to M60 and RTi8 somewhere?
Go with the RTi - don't make the mistake I did, otherwise you will want to spend $$$ on an upgrade later on!Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes) -
i have a tweeter which is approx 40 mins away
Polkyyy wrote:i have a tweeter which is approx 40 mins away
Then swing by Tweeter! I am a first time Polk owner, and have been extremely happy with the RTi8's. They sound very powerful by themselves with my H/K 635. I have noticed the highs are a touch bright in certain songs, but I haven't setup the receiver using the EZsetup microphone either which could improve the sound even more! The RTi8's have great bass for their size too. Listen to both if you can, but if you can budget the RTi8's then do it.
