CD Player for Krell 400Xi integrated amp?
crazy
crazy Posts: 443
edited April 2006 in Electronics
Greetings!
I'm looking for a CD player to go along with my Krell 400Xi integrated amp. Since I spent all my money on my speakers and the amp, my budget is rather limited. I would be stretched to even spend $1K on it - looking for something more in the $400-500 range.
Also, I noticed that the Krell has something called "balanced inputs". Do I need a CD player which has balanced outputs? What are balanced inputs/outputs anyway??
Thanks!
Distant Dream - A New Beginning
www.distantdream.com
(Now also available on iTunes)
Post edited by crazy on
  • adam2434
    adam2434 Posts: 995
    edited April 2006
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • LuSh
    LuSh Posts: 887
    edited April 2006
    Are you ok with buying used? If so i'd check out these.
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtlplay&1148905942
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtlplay&1148166908
    http://cls.audiogon.com/cgi-bin/cls.pl?dgtlplay&1148480749
    Failing that there is always a Rega 2000 planet. At the price you're looking at for CDP's balanced connections will almost certainly do nothing for you, unless of course you need a run of 30ft or so.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    Thanks, Lush.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • crazy
    crazy Posts: 443
    edited April 2006
    Thank you for all those links - that is definitely helpful!!
  • crazy
    crazy Posts: 443
    edited April 2006
    How does the Rotel RCD 02 compare to the RCD 1072? My dealer can get me the RCD 02 for real cheap.
    Also, is it important to get balanced outputs from the CD player (since the Krell has balanced input)?
  • crazy
    crazy Posts: 443
    edited April 2006
    Ok, last post of the day ...
    Has anyone used or heard the Rega Jupiter CD Player?
  • audiobliss
    audiobliss Posts: 12,518
    edited April 2006
    Here's basically what I've been told and how I understand it. If I've missed, misinterpreted, or mistated something, I'm sure someone will point it out.
    First off, the 02 and 1072 are quite different from most other CDPs out there. They both implement the same Burr-Brown (PCM1732 I believe?) 18-bit DAC. Why an 18-bit DAC did you say? It was explained to me that Rotel tried to copy the sound vinyl offers when designing their current series of CDPs. The 18-bit DAC doesn't offer the same peaks in dynamics currently popular 20 and 24-bit DACs offer, but the noise floor is extrememly low compared to most other DACs, thereby making the effective dynamics comparable. In doing this, the energy and impact vinyl offers has, supposedly, been closely approximated.
    Now, on to the differences between the 1072 and 02. The 1072 obviously has a stouter chasis. The 1072 also adds a toroidal transformer and some nicer capacitors in the output stage. Beyond that, they use the same DAC and the same transport. Someplaces are saying the 1072 adds a second DAC, but they both only have one DAC.
    I hope at least some of that's true, and I hope it is of some help. I'm certainly excited as I await the arrival of my RCD-02 sometime later this week. :)
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    Damn. Y'all got me looking at that NAD hard!
    Wes
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2006
    Arcam CD73! I love mine.
    I-Sig,
    Don't you have a Bel Canto DAC 2? If so and you're looking to buy a CD player to use as a transport I'd look at the Arcam CD73 or the Rotel. I had an NAD C521 and the transport is loud and clunky. The 541 might be better but my Arcam is silky smooth and displays text (CD track names, etc).
    When I had my NAD running as a transport into my Bel Canto DAC there wasn't a HUGE difference in sound between the DAC in the NAD and the BC. After upgrading my transport there was a much bigger difference IMHO.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    I-Sig,
    Thanks for the tips. That's interesting that that was the case.
    Wes
  • tryrrthg
    edited April 2006
    Wes
    No problem. I should have mentioned that my upgraded transport was a McCormack SST-1, not the Arcam. I never really got to do a fair assesmant of the Arcam used as a transport for a DAC. However, the Arcam is a nicer unit than the NAD. I "downgraded" from a DAC/trans combo to the Arcam because of some home renovations. I still have the McCormack and I'd like to put it to use some day as it did make a nice difference.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited April 2006
    I can't help you on a CD player recommendation.
    Balanced inputs are XLR connectors with 3 pins in a circular housing. Google Neutrik connectors. If you are going to run the CD directly to your amp, provided the cd will allow this, Balanced/XLR is the way to go. There is a shield in the wire to eliminate RF. If you are going to run it through your pre, does your pre have XLR connectors? If so,run XLR from CD to Pre to amp.
    It may start a wire war, but I have found that XLR will not color the sound the way RCA's will. Using XLR will show the good and bad of all equipment and recordings. RCA and the various wire manufacturers allow us to tune out or in things we percieve we want/need.
    I have a set of Cardas XLR connectors I paid $300 for 1 meter. Built my own with Neutrik and Mogami microphone wire for $29.00. No difference to my ears. Except the name on the wire. I don't like to play the wire game all the time. XLR for me on everything. Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    That McCormack seems to be a really nice unit. I read the little review you linked. So there was even a big difference between the McCormack and the Arcam? I know those are supposed to be in different leagues, but just curious. Thanks.
    Wes
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2006
    My next transport will either be the CEC TL-51x or a Musical Fidelity CDP. I'm leaning towards the CEC. But that's waaaayyyyy down the road.
  • tryrrthg
    edited April 2006
    Wes
    I never really got to compare the Arcam as a transport vs the McCormack. When the Arcam arrived I was too busy working on remodeling our bathroom to listen to everything. I sold my Bel Canto DAC shortly after, so I never got a good listen. However, going off memory, the Arcam (running as a CD player only) is SLIGHTLY more "electronic" sounding than the BC/McCormack combo. There was just an ease/lushness/musical sound to the BC/McCormack combo. The Arcam is a tad bit more "exciting" - I guess that's the word I would chose. I guess it's more of a rock'n out type of sound than a smooth effortless sound of the BC/McCormack combo. My soundstage also got a bit deeper, extending beyond the back wall when using the BC/McCormack combo. In a nutshell the BC/McCormack combo sounded more natural/musical with slightly better seperation, depth, and focus. The Arcam is no slouch though, especially at the used price.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    Thanks for the quick synopsis. I eventually want to get the new tweeters, so a little bit of the rockin' characteristics in the ousrce balanced out by smoothness in the speakers seems like it might be a good combo to me if I go with the Arcam.
    Wes
  • Joey_V
    Joey_V Posts: 8,600
    edited April 2006
    Rotel 1072 would be an awesome addition to your stellar system.
