Using Center Channels as Fronts
Early B.
Early B. Posts: 7,900
edited April 2006 in Speakers
Anyone ever tried using three identical center channels as their front soundstage?
I like my modded BIC center channel so much that I'm thinking about eventually buying two more of them to place upright and use as HT fronts.
"God grooves with tubes."
Post edited by Early B. on
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2006
    I know a Polkie used CSi40's as L&R's....anyone remember who?
  • HiPerf360
    HiPerf360 Posts: 436
    edited March 2006
    I have a M&K set up that uses the same speaker for all three and it sounds very good, actually damn good.
  • Lsi9
    Lsi9 Posts: 616
    edited March 2006
    I have problems with traditional center channels as you can see from my equipment list below. I have a cs350 that I am currently not using. I replaced it with a RM3000 3 peice set with passive sub all for the cc.
    CCs sound like they accentuate the low end mid range for me.
    I prefer my set up to the 350.
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • aaharvel
    aaharvel Posts: 4,489
    edited April 2006
    if you don't mind that whole cascade crossover thing with your front pair, then yeah i guess it would work.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    I've done a couple systems with all centers (for fronts at least) with Klipsch speakers and haven't had a problem yet! I haven't tried a Polk or any other brand but the big K's loved it. No problem here.
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2006
    What do you do about the loss of most of the bass? I've made the mistake of forgetting to turn on my main speakers & just had the center & surrounds playing. It was the lack of bass where I knew should be that made me realize that I forgot to turn on my amp for my mains.
  • Toxis
    Toxis Posts: 5,116
    edited April 2006
    Hmmm... add a sub? ;)
  • Ron Temple
    Ron Temple Posts: 3,212
    edited April 2006
    A friend is using 5 GR Research AV2s powered by monoblocks hooked thru a Marantz 8300, very nice.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • HiPerf360
    edited April 2006
    I had the crossover set the same for all three front speakers...
    So no loss of bass here
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2006
    I belive that would be LiquidSound...
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2006
    The only problem I see is in the pocketbook as a good center can go for almost as much as a roughly identical pair of mains.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Early B.
    edited April 2006
    The center channel I'm referring to sells for $100 NIB.
  • Early B.
    edited April 2006
    Just ordered two stock BIC center channels for use as my fronts from amazon.com for $105 ea. with free shipping. Will report back when they arrive. It'll be interesting to hear if they sound as good as the $2300 (retail) floorstanders that formerly served as my fronts.
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2006
    I played with my CS400's as mains for a while. Not bad, but I have a few better choices around.
    Also played with my f/x1000's just for grins. Actually they were much more fun and more enjoyable, but...
    More later,
    Tour...
    Vox Copuli
  • Early B.
    edited April 2006
    Just got the BIC center channels for my fronts. At first listen, they are very capable speakers. Sounded about at 98% of the floorstanders I had before. They are a bit brighter, which was to be expected, but they were not annoying. Detail is pretty decent, too. For the price, they are absolutely unbeatable, so overall I'm quite pleased with the purchase. Hopefully, both the level of brightness and detail will improve as they break in. The crossover is very simple and begs to be tweaked, so someday I may fool around with doing that.
