Who uses Vibrapods?
Ron-P
Just ordered up 2 sets from the Polk store (thanks Micah and Shelia).
Anyway, what are your thoughts? Experiences with/without them?
Peace Out~:D
Peace Out~:D
If...
Ron loves a film = don't even rent.
Post edited by RyanC_Masimo on
They bake up real nice.
(They do. It's in the manual. You'll see.)
MC -
Micah, please O please do not put anything else in the box with them. If I open it up and see a sock, I'm calling the haz-mat team in.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
I wish I could help but I have not installed mine yet. The only useful thing I can say is to use different models on the same piece of equipment if the weight is not distributed evenly. For example my amp required #4's on the back and #2's on the front. I weighed each of the 4 sides by sitting two feet on a bathroom scales while sitting the other two feet on a phone book. If I had used the #3's all around the front two would be stiff and the back two would be squished.
I might need some now, the VTF-2 rocks the entire basement. We will see if anything is disturbed after a couple of movies.
Or you could just take a semi-inflated 12" inner tube and put it under yer sub. Makes my sub more isolated than a russian gulag... Tightens up bass and keeps glasses from falling off my mini bar
LOL!
MC -
I use them, Ron. Under my CD, DVD, and VCR. I have not tried doing an A/B comparison. I did use them under my old AudioSource SW-15, and they did make a difference there, though the change was probably more due to raising the sub off the floor. I did not install the glass shelving between them and the components, just put them under your units, and make sure none of the existing feet touch down.Please feel free to visit my Home Theater Page at The Bailey's Home Theatre in our Living Room.
