Preener
reeltrouble1
reeltrouble1 Posts: 9,312
edited April 2006 in 2 Channel Audio
So I have been using a lint free cloth with a bit of Distilled Water on it to wick away the debris that collects on my Preener, I see where the company recommends a bit of moisture on the Preener prior to its use to help with static control. Anybody use anything else??
RT1
Post edited by reeltrouble1 on
  • madmax
    madmax Posts: 12,434
    edited March 2006
    I shouldn't ask but what the heck is a Preener and why don't you want static on it?
    madmax
    Vinyl, the final frontier...
  • reeltrouble1
    edited March 2006
    Parostatik Preener= a very nifty round "brush" used as a final touch on your vinyl to remove any surface particles and control static build-up which may have occured in the cleaning process.
    I really like the brush.
    RT1
  • TroyD
    TroyD Posts: 13,083
    edited March 2006
    That's what I do with mine......Tour would be the expert.
    BDT
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2006
    Yup... Edwin Watts knew his vinyl...
    Ted,
    Pop off the end cap and there's a wick inside. Remove it and soak it in distilled water, shake out the excess and put it back inside. In no time the preener will be moistened.
    As for cleaning off accumulated LP stuff.... I've always used an old sytlus brush.
    More later,
    Tour...
    Vox Copuli
