Higher volume with age?
It seems that since I've put my system together the volume has totally decreased in output. I know as I sit here, that it does make sense a little bit but here's what I'm running into:
I started with a Denon 3805 and RTi8's. I added the rears (RTi4) and Center (CSi5). I just bought my SPL meter, and have yet to calibrate but over the past few months, I have had to increasing turn up the volume.
I started with just the 8's and -10db was VERY LOUD. Now with the rest of the speakers on, I have to run my HT at -5db just to get it loud enough to hear clearly. Is there something wrong with my speakers? Or is it just with the added speakers to push, the overall volume has decreased?
I was worried at first that I had damaged the speakers, but really, -5 isn't that loud is it?
Is it that time already to consider separate amp for the mains?
Or will calibrating it fix a lot of those problems?
Thanks!
David
Thanks!
David
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Post edited by MrNightly on
Hi David, age has nothing to do with it.
What you are noticing is that your Denon as good as it is, is working overtime to run all of your speakers. The more speakers you add, the harder it is to get the same volume as you started out with. The only way to get it is to turn it up louder!
Before I got my Parasound & Outlaw amps my normal listening level was -20 to -30. Once I added the amps, it was way too loud & now my normal listening level is -40 to -30!
You figure it out from there!;)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Nah, what's really happening is that you're going deaf.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
unc2701 wrote:Nah, what's really happening is that you're going deaf.
Ha. That's what I figured it was.. sucks to be me eh?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
cfrizz wrote:What you are noticing is that your Denon as good as it is, is working overtime to run all of your speakers. The more speakers you add, the harder it is to get the same volume as you started out with. The only way to get it is to turn it up louder!
So, it won't hurt my speaks to crank them harder? Or wear out the AVR sooner?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
I'd say it is time for an external amp if you want to acheive the desired volume without overtaxing your receiver.
Based on everything else I said, what do you think?MrNightly wrote:So, it won't hurt my speaks to crank them harder? Or wear out the AVR sooner?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
cfrizz wrote:Based on everything else I said, what do you think?
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Did you just lecture me?!?I feel like i'm 11 again. Gee thanks.
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
WAAAAAAAA!!!!:D Fine I'll just come right out and say it.
Go right ahead & turn it up. Just don't come on here whining when you burn out your speakers & receiver!;)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
That's encouraging. Thanks a lot
I guess I will need an amp before long then. Another thing to add to this never ending list
Oh ya, and thanks for the encouragement. It means the world to me :PHonoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
cfrizz wrote:Hi David, age has nothing to do with it.
I did not notice this change when I added my Outlaw amp. My amp made sound clearer and opened up the sound of my surround speakers. I continued listening at the same level, but in a more enjoyable and clear environment.
I am not saying that CFrizz is wrong with his assessment, this may very well also be the problem. I am just stating that the addition of an amp may not affect your volume/gain setting but it will most certainly make things easier to hear because of increased clarity.
BTW... I am convinced I upgrade my stereo to compensate for my hearing loss and buy bigger TVs to compensate for my poor eyesight. Aging is a great excuse to upgrade!Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote
