FX/500i placement?
edited April 2006 in Speakers
I just finished completing my set of Polks. Fronts are RTA-12C, center is CS-400i and surounds are FX/500i. None have been set up yet. I have heard that the 500's should be to the direct left and right of the listening position. It is far more conveninet to place them behind me. Any thoughts on what I should do and should they be in bipole or dipole set-up? I'm sure that this has been covered before but I am new to the Polk family.
Rick
Post edited by Familycat on
Welcome!
    edited March 2006
    Rick,
    Welcome to club Polk. it's fun in here. YOu'll learn alot.
    With the FX series of speakers you can place them either on the side of you or behind you. They are very flexible and forgiving. They fire off the sound in two directions because of their design.
    I believe they might be marked left and right... make sure you place them correctly that way. Keep them about 3 feet high on the wall from your listening level. That usually means a foot to a foot and a half from the ceiling if you have a typical 8ft ceiling. Also, place them at least 6 feet apart from each other... more distance won't hurt either.
    good luck and come back and ask more questions if you got more.
    AL
    PolkFest 2012, who's going>?
    edited March 2006
    danger boy wrote:
    Rick,
    AL
    Thanks for the info. Very helpful.
    Yes, I have been learning a lot. It seems the more I learn the more I realize I don't know.
    Yes they are marked left and right. Any thoughts on the bi-pole/di-pole knob.
    As tor the CS-400i center channel, is it really a benefit to bi-wire the speaker?
    edited March 2006
    Oops. sorry left out the bi/di pole answer. If my memory serves me right.. the di pole setting if if you place your FX speakers on the sides of you. and bi pole if they are behind you. Play around with both those setting once you have them on set up. Mine are on the side wall and sounded best in bi-pole setting.
    No benefit to bi wire your center channel. Although if you're curious about it.. give it a try. that's they whole thing about home theater. Yes, there are basic set up guidelines, but each set up in a person's home is different. We all have different room sizes, different gear, different hearing too. So nothing is set in stone as far as the "perfect" setting or placement. Just guidelines.
    edited March 2006
    Will do.
    I noticed you are running an Outlaw pre-amp. How do you like it? I am considering purchasing a LMF-1 sub. I am also looking at the Velodyne SPL-1200. It is double the price. Your thoughts please.
    I need a complete set of cables and speaker wires. My old system is 10 years old. Not many options then. Fiber optic, progressive scan, analog, digital, co-ax. Not sure where to start. They vary greatly in price. What should I look for and where should I purchase?
    Rick
    edited March 2006
    familycat,
    sounds like you have a very nice home theater setup going there. as for cables, it would help if we knew what electronics that you have, that way we can help you with what cables you need. as for brands, i would stay away from Monster, most of their stuff is overpriced for what you are getting. if you dont mind buying from the internet blue jeans cable (http://www.bluejeanscable.com/) and Signal Cable (http://www.signalcable.com/) sell very good quality stuff for reasonable prices. if you would rather purchase something in a store, i would probably go for some of the Accoustic research stuff in BestBuy or CircuitCity or some of the nicer stuff from Radio Shack. It all depens on your budget.
    edited March 2006
    if you're placing the fx500i's on the rear wall I recommend switching the "LEFT" and "RIGHT" speakers around and using the Bipole option.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
    edited March 2006
    Why? There is a reason they are Left and Right.
    edited March 2006
    when they are on each side they fire one way but if you put them behind you they fire differently.
    It is just a preference; I thought about doing this with my fx1000's b/c they are on the ceiling behind the listening position.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
    edited March 2006
    when you use monopoles, the woofer is facing the listener yeah?
    well if you use a 1-woofer bipole speaker and you use it's designated "RIGHT" AND "LEFT" placement on the rear wall, the woofer fires right to the side wall. Doesn't make any sense.
    Since Skynut's Fx1000's have two woofers in each enclosure, it doesn't matter.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    edited March 2006
    mldennison wrote:
    familycat,
    The system thus far:
    Reciever-Pioneer Elite VSX-74TXVi
    DVD-Older (4-5 years) Sony Progressive Scan not sure of model
    VCR-Older (6-7) Sony not sure of model
    TV-Sony KD-34XBR970
    Sub-Outlaw-LMF1
    Front POLK RTA12C
    Center CS-400i
    Surround F/X 500i
    Hope this helps,
    Rick
    edited April 2006
    I have the f/x 500's and wondered about the woofer facing the wall when they were mounted behind. So they should be switched out so the woofer faces the listening position right? Also, my couch is on the same back wall where the speakers are mounted so are they behind me or really to the side??
    AVR: Onkyo TX-SR604/s
    Front: Polk Rt1000i
    Center: Polk CS400i
    Surround: Polk FX500i
    Subwoofer: Polk PSW110
    edited April 2006
    bionic if you're against the back wall don't even bother. Just put the FX's on the sides, in dipole mode, and stick with 5.1.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    edited April 2006
    See, thats where the problem comes in....I cant put them on the sides so they have to go on the back wall. If they were on the sides the only place that I could place them would be too far out in front of the listening position. So I guess that I am stuck with them on the same wall that the couch is placed on. I just really wasnt sure in my settings if that would be considered behind or to the side, I just assume that since they are facing forward that it would be behind right? So I should still switch them around so the the woofers are facing towards the listening position in bipole right? I appreciate your help.
    Front: Polk Rt1000i
    Center: Polk CS400i
    edited April 2006
    10-4
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    edited April 2006
    Good lookin out, I appreciate it.
    Front: Polk Rt1000i
    Center: Polk CS400i
    edited April 2006
    They system is up and running. The system sounds very good. I have the F/S 500's on the back wall in the bipole position with the driver pointing away from the listener. I will try switching them. The CS-400i sound good. The RTA12C's are warm and clean but not much bass. My old Pioneers HPM's had much for punch while not as clean. I purchased an Outlaw LFM-1 sub and helped significantly. The Pioneer elite reciever is awsome. Still making adjustments. Though I would share.
    Rick
    edited April 2006
    Good deal, glad you are happy.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    edited April 2006
    hey rick,
    as i meantioned to you,if you e-mail me your address, i'll send you the owners manual or you can pick it up at the airport.
    bill
Welcome!
Welcome!
