Question About Choosing the right Subs.
nOoBie
nOoBie Posts: 2
edited April 2006 in Car Subwoofer Talk
Okay, im new but i have been trying to do some research on which subwoofers to buy. I listen mostly rock/rap, so my brother told me I should get 2, 10". I want something that hits pretty hard, but not so hard that its breaking peoples legs when I drive by, or shattering my windows. My brother suggested Infinity, or Rockford Fosgate. I dont really know much about them so I tried looking at them on Ebay. It seems you could get an AMP and 2 Subs for roughly 200-400$ off ebay. My bro says he knows how to install everything... I would just like to know how do I tell how many WATT amplifier I need.
2 SUBS 100$+30$ shipping: http://cgi.ebay.com/2-INFINITY-REFERENCE-1042w-10-DVC-SUBWOOFER-CAR-SUBS-P_W0QQitemZ9704415184QQcategoryZ3291QQrdZ1QQcmdZViewItem
AMP 120$+30$shipping:http://cgi.ebay.com/INFINITY-REFERENCE-310A-Monoblock-Amplifier-NEW-04-AMP_W0QQitemZ9702238013QQcategoryZ18797QQrdZ1QQcmdZViewItem
Post edited by nOoBie on
  • aaharvel
    aaharvel Posts: 4,489
    edited March 2006
    Macleod knows everything about Car Audio. You can try pming him. I usually stay away from the Car Audio section. However, IMO unless you're going for pure SPL, it's a waste to use 2 subs b/c everything below 100hz. is essentially mono anyway. Buy a single DVC subwoofer and bridge it to a 2ch. amp.
    Welcome to Club Polk.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2006
    I wouldnt say I know everything.....but I am always right! :D
    You dont use 2 subs to be stereo, its all about moving more air and getting more volume. So if youre after good thump and not so much perfect SQ, then 2 subs wouldnt be a bad way to go.
    As for Intinity or RF, both are good however I would take the RF. Stay off Ebay. Way too easy to get ripped off there. Youll have to pay a little more but buying from an authorized dealer is so much better all the way around and there are great deals to be had out there.
    For example, here is a great sub. Good output and great sound quality. $76 each. Thats $152 for a pair of great, brand spanking new, straight from the manufacturer with full blessing and warranty.
    For an amp here is a great Profile amp for $160. Again, brand spanking new and authorized. Profile aint as an exotic a name brand like PPI or Xtant, but they will make their rated power cleanly and are well built and cost half the price. They are a great budget/starter amp.
    So there is a great system for $325 or so and they have free shipping. Thats just a little bit above what you could get from Ebay but this way youre getting good quality gear, properly powered and fully authorized.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited March 2006
    I think you are wrong on that, actually just on the last part of that statement :D.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • nOoBie
    nOoBie Posts: 2
    edited March 2006
    well... I have never had a bad expirience off ebay, and i have been using for a long time, i do my research before I buy making sure they have 99%+ posative feedback. Thanks for the advise..
  • 1996blackmax
    edited March 2006
    Just because someone has 99% feedback does not mean they are good to buy from. There are many sellers on there with that rating, but with also hundreds of negatives.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • MacLeod
    edited March 2006
    The thing thats tricky about buying electronics off of Ebay is its hard to tell if youre getting crap or not cause you cant see inside of it and even if you could you still couldnt tell because theyre so moody. Something like, say, furniture you can see if its broken or scratched. You can clean up the outside of an amp to it looks shiny and new and it may even work fine for a few hours then quit.
  • Stroker
    Stroker Posts: 30
    edited April 2006
    just learned that blems and returns are getting sold on ebay .. if the speaker has any defects as in aperance outer ring out of position . Best to pay with paypal then u can file a claim and get your money back i have had to do this before and I got my money back.
    88 Wrangler 383 stroker 525hp 10 inch's of lift 38.5's
    Premier 860mp 140 & 200 amp altenator
    MMC6500 driven vy c300.2
    MMC690 driven by c300.2
    2-MM2104's driven by c500.1
  • Meeks32
    Meeks32 Posts: 330
    edited April 2006
    Why not get one very good 12" for $160ish instead of 2 ok 10's? You would have a smaller box & just might come close to spl of the 10's. I got my eclipse aluminum sw8812 off ebay brand new a few months ago for $150.
  • Stroker
    Stroker Posts: 30
    edited April 2006
    thats a good price
  • Stroker
    Stroker Posts: 30
    edited April 2006
    Ebay has good deals but you do have to beware . alot of blems , b stock and returns. I have had good luck so far
