Couple Easy Questions
riglehart
riglehart Posts: 276
edited March 2006 in Vintage Speakers
I just got some 11T's and had to put new drivers in one. Two questions...
1) Inside the cabinet, does the black or white wire go on the + terminal of the driver? The new drivers have terminals with +/- labeled (6503). The old ones (6510) have a red dot on one side.
2) On the old drivers is the red dot the positive or negative terminal?
Looks like they were worked on before, want to make sure everything is in phase.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
    F1nut Posts: 51,771
    edited March 2006
    White or Green is negative.
    Black or Blue is positive.
    If you have any other colors in there somebody has been messing with them.
    The red dot is positive.
