HT Plan for Multi-Zoned Home
haveyouever
Gents,
I plan on installing a home theatre in a newly constructed 3 story 4,800 sq ft home made of steal and concrete located in Cozumel, Mexico!! The home was not designed/prewired for sound or network access... and did I mention the walls are all steal and concrete!!... It will consist of 6 bedrooms, a dedicated HT room, and roof access for entertaining guests. It would be ideal to have sound in all locations of the home, including outside around the pool and roof areas. I hope to complete this project by one trip out of the country.
I've enjoyed the support from this forums knowledge base, and I call on it once again to help in formualing a plan to install a mulit-zone HT with out the advantage of pre-design/construction access to the walls and floors. Your thoughts are appreciated in advance!!
Which, brings up the point!!... has anyone had experience with setting up wireless speakers?... or... am I barking up the wrong tree???....
Post edited by haveyouever on
I never heard a wireless speaker I liked. Maybe someday.
RT1 -
With steel and concrete as your overiding design, conduit running all over the place sounds like the order of the day. Call it the Exoskeleton Theater.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I do hope you aren't going to leave the interior walls exposed concrete, are you? The echoes will kill...
When you finish the interior, allow space. 3/4" furring strips attached to the walls to hold the sheet rock will give you plenty of room. Slot the backside to give you a wire chase.
And invest in a rotary hammer drill. I have a Bosch Bulldog...
