rears for 7.1 system (all polk)
schwerhaiv
Hi,
I have Rt20p's, CS1000p and FX1000's. I am looking for some solution for the rears. Does anyone have speakers they are looking to unload that would match this setup? Thanks,
-SchwerhaIV
-SchwerhaIV
Post edited by schwerhaiv on
I have a pair of LSi9s for sale.
...You're not using the FX1000's for the rears?
-Luc -
OH yeah I am !!! On both systems !!! I am selling off my LSi9s as I used them for the front channel speakers.
I imagine he's using the FXs for the side surround and is looking for another set for the rears...
Those LSi9 are nice but overkill for the rears IMO - and aren't voice matched with the rest of his gear... -
there's some fx500's on ebay.
http://cgi.ebay.com/PAIR-POLK-AUDIO-F-X500-BOOKSHELF-SURROUND-SPEAKERS-EX_W0QQitemZ9706916073QQcategoryZ71572QQrdZ1QQcmdZViewItem
they'll timbre match your 1000's. -
Thanks, all. I picked up a pair of RT600's on the bay. I think that they should work for the rears. And yes the FX1000's are being used on the sides. Thanks, however.
-SchwerhaIV
