TV bug
TheReaper
I have a problem with my rear projection tv. There is a spider crawling up the screen, on the inside
Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
Post edited by TheReaper on
"Objects on the screen are larger than they appear" :eek:>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
RAID!!!!!!!!
PolkFest 2012, who's going>?
haha ... RAID yes ... or insect trap in the projector !!!
My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
i had the same thing happen to my lcd rear projection happen last summer. Haven't seen the little bugger for a quite awhile ...think he might have starved in there.Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W -
As I only saw him crawl by 3 times this weekend. I will probably leave him in there, rather than tear apart my tv.jayman_1975 wrote:...think he might have starved in there.
Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
Play Starship Troopers. That'll scare him away.
He wondering when you are turning off the lights / TV.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
You need to read your manual, that spider eats the chromo-bug, leave it alone.
RT1 -
It should die in about a weeks time.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I had the same thing and took the screen off to clean him out.
I found that I needed clean anyway.
What a difference that made.
Clean the screen.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
reeltrouble1 wrote:chroma-bug.
RT1
Ted, I believe that went over many heads around here. I call it the generation gap thing, where the younger ones never experienced what you have in your time.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
