Reverse Banana Plugs Anyone?
Early B.
Early B. Posts: 7,900
OK, here's what I'm trying to do --
I will be using the speakers on my 2-channel system as my HT fronts, so whenever I want to watch a movie, I'll carry the speakers into the den and hook them up to the receiver. For the sake of convenience, I would like to use the same speaker cables on my 2-channel system and hook them up to my HT system along with the speakers. However, it'll be a hassle if I have to plug the speakers into the back of the receiver every time I watch a movie.
So here's what I'm looking for -- a pair of "extensions" for speaker cables (about 2 -3 ft.) that will remain plugged into the receiver and the other end can "receive" banana plugs or spades. Has anyone ever run across something like that?
If not, any ideas on how to make them? I thought about getting two sets of binding posts and using 2 ft. runs of speaker wire to attach the binding posts to the receiver, but I'd like to find a more suitable alternative.
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2006
    A good set of gold plated 1/4" mono phono plugs and jacks should do the trick.
    Put a banana on one end to hook to receiver, a jack on other end. Build four for each system. then a twin male (4) speaker wire.
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    Another option could be to use the posts for a wall plate like below. Each side of the post would accept bananas or bare wire.
    http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=091-1206
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    Adding to my reply above, I'd also use some heat shrink tubing over the posts (and any exposed connectors or bare wire) to insulate the pos and neg from each other. Accidently touching the pos and neg together will shut your amp/receiver down instantly, or worse. ;)
  • Early B.
    edited March 2006
    Thanks, Adam. The link you provided is a good option.
  • adam2434
    adam2434 Posts: 995
    edited March 2006
    You're welcome and good luck with whatever you choose.
