Drawing Floor Plans
audiobliss
audiobliss Posts: 12,518
edited April 2024 in Clubhouse Archives
I'm trying to draw the floor plan for my room on my computer. Here is my first attempt, as I attached it to my Hi-Fi thread. Earlier today I sketched the layout of my room on a piece of paper and measured out where everything is, and now I'm trying to duplicate that in Paint so I can attach here. My problem is trying to get it to scale. I figured that my room is 13'5" x 13', so I'll let one inch represent 1 foot. Ok, that's cool. So, now while I'm drawing, I use the 'status bar' on the bottom of Paint so I know how long to make my lines, so it'll all be in scale. BUT, the status bar is giving me distance in pixels. Well, I found online that one inche is 96 pixels, so I've been using that conversion factor. However, it just doesn't look right. And even if it were comign out right, surely there's an easier way to do this?
Any body have any ideas of what programs I can use to do this? Or a way to make it easier to do it in Paint?
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
  • neomagus00
    neomagus00 Posts: 3,899
    edited March 2006
    inches to pixels depends on your resolution... perhaps if you made 100 pixels equal one foot, that'd be easier (or 120 pixels to a foot, so it's 12 to an inch)...
    barring a program with an accurate ruler (i'm thinking of my CAD program here), it's gonna be really hard to get it to the 1-foot = 1-inch scale...
    i'd personally do 120 pixels = 1 inch
  • audiobliss
    edited March 2006
    Thanks. I'll play around with that for a while. So that means that, for my 13'5" x 13' room, I would make the area of my screen in Paint be 19320 pixels by 18720 pixels? Ain't that gonna be HUGE?!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited March 2006
    Yeah, that won't work...I don't have enough resources on my computer for that! :p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited March 2006
    Well, I just did it. Took me forever, but I measured off everything in my room and I came up with the floor plan of my room to scale. However, for some reason it's 10MB! What can I do to make is smaller so I can attach it?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • brettw22
    brettw22 Posts: 7,623
    edited March 2006
    Resize it to 20% of it's size......
    Or send it to me at Brettw22@aol.com and I'll resize it for ya.
  • audiobliss
    edited March 2006
    Thanks. I just found the 'Stretch/Skew' option in Paint and resized it. Down to 75kb now! :D
    Thanks!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • MattN03
    MattN03 Posts: 558
    edited March 2006
    You're best bet for a scale drawing is to find someone that can create a Autocad drawing. Of course, that may be easier said than done. That is what I used to draw our floor plan to send to SVS for sub placement suggestions.
  • audiobliss
    edited March 2006
    I think my version in Paint turned out pretty well, considering.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • schwarcw
    schwarcw Posts: 7,359
    edited March 2006
    There are a lot of floor plan layout for home desing out there for about $20. The ylet you drag adn drop furniture, add color and preview in 3-D. Pretty cool stuff. Most Comp USA's and Best Buy's have this softward. Also check the web.
    Carl
